Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 08-30-2004, 03:38 PM
spacecrow spacecrow is offline
Unhappy backup lights not working in 1972 Chevelle
My backup lights are not working. I have a shop manual and a good vom. Fuse is good but have not checked the voltage there. Any advise? Thanks for any replys.
Old 08-30-2004, 06:11 PM
96Civ's Avatar
96Civ 96Civ is offline
Re: backup lights not working in 1972 Chevelle
Can you check the wiring to the back lights in your trunk? I had a similar problem with my car and I had found out the junk in the back of my car just knocked the lightbulb out of its socket.
Old 08-30-2004, 06:53 PM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
yup yup, what he said^^. its a commen problem with my 68, except its usualy my bliker/brake light. the next thing i would check after the fuse, (actauly i would probablyu check if first), but seeing as how you already checked the fuse, just look in the trunk at the actual bulbs, and the sockets to make sure that everything is as it should be, i cant think of where the actualy lights are mounted on the 72's, but no matter where, look at the sockets and lights.
<<my engine
<<part of the front end during engine swap
other pictures of my car... click here
Old 08-31-2004, 08:23 AM
Thumbs up those are good ideas
I'll be checking for a bad ground too! A common problem. A vom is a life saver in these things. As long as the wire does not route through the steering collum, I should be ok. Thanks!
Old 09-03-2004, 10:37 AM
Talking working fine now
It was the ground that screws into the sheet metal. Sanded off the metal and put a new lug on.
