Go Back   Automotive Forums Car Chat > Buick > Century
Old 04-13-2012, 07:13 AM
SAelmer SAelmer is offline
no low speed heater/ac fan
the first 2 fan speed settings suddenly quit on my '02 century.
I checked and swapped the fuse, so doubt that's it.
Is there a relay someplace I need to check?
Or a vacuum line perhaps?
Where can I find a schematic of the circuit?
Old 04-13-2012, 07:29 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: no low speed heater/ac fan
You will need to change the fan resistor that is located next to the fan under the dash. The resistor controls the fan speed. It will often start with the lowest speed going out and then each higher speed. Only 5 will work when the resistor is fully gone. They are not hard to change just hard to get to.
The Following User Says Thank You to GTP Dad For This Useful Post:
SAelmer (04-13-2012)
Old 04-13-2012, 08:05 AM
Sounds like the voice of experiene - thanks!
As I've never pulled my dash apart - any clue where I begin or what area/part I need to go after to expose the motor/resistor?
Will the resistor be a dealer part replacement, or will AutoZone/NAPA have?
Old 04-13-2012, 08:36 AM
Tech II Tech II is offline
Drop the lower hush panel on the passenger side......find the wire harness to the blower motor......just follow it back to the resistor block...the resistor block and harness is what you are replacing.....any parts store will have it...
The Following User Says Thank You to Tech II For This Useful Post:
Old 04-13-2012, 11:46 AM
I have removed the hush panel and followed the motor wires to a black box like unit. suspect that's it. tight fit to one nut/screw that is visiable. Haven't yet removed it.. hesitant if not right "thing". thought I'd go to NAPA and see what they show.
Old 04-13-2012, 04:00 PM
Okay, so after messing around upside down under the dash - I have succeded in removing only 1 of 3 screws! There appears to be 2 semi-hidden behind rubber sound matting - that I can't remove. My bifocal's don't help either! Or my age, nor my shakey hands!
I do hate to give up and pay for 2 hrs of severice time to have some shop do it.... but it may come to that. Or we could just run AC fan at higher speeds and wife can cover her legs with a blanket!
What do you all vote for?? LOL
Old 04-13-2012, 06:20 PM
I attach a 5.5mm socket to a 1/4" swivel, and attach that to an extension....you force that socket on the screw, passed the rubber....you don't have to remove the two back screws...just loosen them 1 turn.....remove the front screw.....now pry down the front edge and grab with a pair of pliers and give a yank....comes right out.....the rear of the r-block is notched......so it is easily put back in, and just tightening the front screw is all that is needed.....
Old 04-13-2012, 06:48 PM
Makes sense to me.. if I can "see" back there with my bi-focals! I'll give it a shot tomorrow when my brain isn't still enjoying Friday night Happy Hour!
Old 04-13-2012, 07:40 PM
Pontiac Guy
I also found it easier to get to if you remove the front seat. A lot of work but makes it much easier to get to the area. Especially since you don't need to stand on your head.
Old 04-13-2012, 07:46 PM
DeltaP DeltaP is offline
I've been known to put my bifocals on upside down when working under the dash! I've read about "Industrial" glasses that have bifocals on top and bottom of the lens but haven't been able to locate them yet.
Old 04-14-2012, 08:05 AM
Pontiac Guy
Try contacting a company that provides industrial safety glasses. They do make lenses with bifocals on top an bottom and for those of us who are bifocal impaired they do work well. They are called Occupational Bifocals. You may be able to obtain a pair from you eye care professional or a company like Eyeland.
Old 04-14-2012, 11:13 AM
Job completed successfully
Thanks for the very helpful input Tech II I was successful in getting the 2 back screws loose enough to slip the unit out. Left a little blood behind , but no worse than usual for under dash jobs!
O'Riellys had the unit in house, so all said and done in less than 1.5 hrs. And my shop rate is a lot cheaper - a cold Miller's and some chips!
Old 09-17-2012, 06:45 PM
rmignol rmignol is offline
had the same tbl on my 2000 century, bought the part , same bifocial problem, got a local guy to put it in took him about 5 minutes 20 bucks later all done
Heater/AC fan doesn't work on low speeds gjthomas48 Camry/Camry Hybrid/Vista 10 07-29-2008 04:22 PM
2000 camry's heater/ac fan doesn't on lower speed but works on max speed? minh100 Camry/Camry Hybrid/Vista 4 01-14-2007 11:09 AM
Low Pitch Squeal in Heater/AC Fan jerryhyland Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 11-18-2004 03:14 PM
2000 Low Speed Heater / AC blower not working btsander Cavalier 1 12-29-2003 08:32 PM
