Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-13-2007, 08:59 PM
minh100 minh100 is offline
2000 camry's heater/ac fan doesn't on lower speed but works on max speed?
Can somebody help me with this issue on camry 2000 LE heater/ac fan. It doesn't work on the lower mode but works on the max mode.
Thank you very much
Old 01-13-2007, 09:04 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 2000 camry's heater/ac fan doesn't on lower speed but works on max speed?
Welcome to the AF!
It is most likely a bad connection or bad resistor on the resistor block that controls the current to the motor. See the discussion in the following links:
http://www.automotiveforums.com/vbul...d.php?t=252829
http://www.4crawler.com/4x4/CheapTricks/Blower.shtml
This information was available in the FAQ thread.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 01-13-2007, 10:16 PM
Is the resistor at the same location as other vehicle has which is next to the gas panel. Do you have picture of it and please provide it to me.
Thank You
Old 01-13-2007, 11:49 PM
Brian R.'s Avatar
Resident Chemist
See the Body Electical section of the Camry Manual at:
http://oregonstate.edu/~tongt/camry/99/index.html
Old 01-14-2007, 11:09 AM
Thank you so much for your help and time.
Thank You
