Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 04-10-2012, 02:21 PM
freekmn freekmn is offline
Exclamation 1997 EGR Problems
I have owned my neon for a couple of years now and now it is starting to have problems when in gear but it idles fine. i took it to a mechanic and he hook a diognostic computer to it and it told him that it had a vacuum problem. i then took it in to my shop at school and i found out that it also had and EGR valve problem. Does anyone know of a direct way to fix this problem?
Old 04-11-2012, 07:54 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 1997 EGR Problems
The cheap fix is to pull it, clean it up with a degreaser and reinstall and see if that helps with the sticking issue. 2nd cheapest option is to block it off using a nickel and dime! This will cause your CEL to light up and if you have to pass emissions, then not an option. Last option is to replace it. www.rockauto.com has some on closeout sale for $33.79 for a DOHC one.
2003 Dodge SRT-4
1997 Geo Metro LSI 4Cly Auto shitfing Problem Zechariah Metro 2 09-28-2009 07:09 PM
EGR replaced but engine light still comes on code shows EGR problem. RobDDDD Impala | Impala SS 2 10-16-2008 08:53 PM
1994 LeSabre EGR Problem ront LeSabre 6 11-06-2003 12:43 PM
1995 GA SE, 3.1 EGR Problem craz-e-e Grand AM 1 11-06-2003 06:18 AM
egr problem logicisall Metro 3 10-24-2003 10:19 AM
