Old 11-04-2003, 10:32 PM
ront ront is offline
1994 LeSabre EGR Problem
1994 Buick LeSabre
3800 engine
148,000 miles
Engine misfires/chuggles at part throttle and light load (about 60 mph). Has good acceleration/performance otherwise.
P1406 History code.
Scan tool shows EGR Actual % swings wildly when the chuggle happens but the EGR Desired is steady..
Engine runs great when EGR is unplugged.
Tried a new EGR valve and it didn't fix the problem.
Intake manifold vacuum is high and steady when EGR is disconnected.
I could use some suggestions!!!!
Thanks
Old 11-05-2003, 03:06 PM
RABarrett RABarrett is offline
If the sensor was replaced when the EGR was, the problem could be the way the ECM processes the info from the sensor. If the ECM cannot process the info, it will dither the EGR valve attempting to come to grips with the erratic info. Ray
Old 11-05-2003, 05:06 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: 1994 LeSabre EGR Problem
Dumb answer-> Leave the egr valve disconnected!
Smart Answer->get the ecm checked out.
Old 11-05-2003, 06:55 PM
Re: Re: 1994 LeSabre EGR Problem
Thanks!
I was really tempted to go with the dumb answer but I just picked up a new PCM today and will install it tomorrow. It better fix the problem or I will use the dumb answer!!!!!!!!
Ront
Old 11-05-2003, 08:33 PM
tman's Avatar
Pimpin' ain't easy
Re: Re: Re: 1994 LeSabre EGR Problem
if you use the dumb answer, make sure you wrap the connectors in electrical tape.
Old 11-05-2003, 09:22 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
What sensor are you talking about? This EGR is not a Ford EGR!!
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 11-06-2003, 12:43 PM
The new PCM took care of the problem so I don't have to go with the dumb answer.
Thanks to all that responded.
Ront
1994 Corsica Won't Start Ragarianok Corsica 0 05-09-2010 04:53 PM
1994 Lesabre Major Problems!.. Irritating! T_MaK_510 LeSabre 1 10-19-2007 10:22 PM
97 LeSabre EGR problem jcc3inc LeSabre 3 06-06-2007 10:17 AM
1994 LeSabre engine running rough, accelleration problems mrmajestyk LeSabre 8 10-10-2004 01:11 AM
1994 gmc egr problems need help blackhawk5177 Sierra 2 12-14-2003 09:24 PM
