Old 10-07-2003, 10:17 PM
logicisall logicisall is offline
Question egr problem
I have a 91 Metro LSI 3 cyl 5 speed. From CA, so has that EGR system.
Getting code 51 on ECM, which is EGR. Went thru Factory Manual trouble shooting:
ECM is providing correct voltage to solonoid.
Solonoid controls vacume with 12v.
Modulator appears to work with pressure
EGR moves with vacume.
One place in manual says solonoid should be 120ohm, mine is 300ohm, which is what another place says it should be.
Check Engine only comes on after fairly long drive, and sets the 51 code again. Any ideas what to check? I am in AZ, and really don't need the extra CA emissions stuff, but would not want to damage the engine by just blocking it off.
Doesn't the EGR introduce exhaust gas to cool the mixture under heavy load?
Old 10-09-2003, 01:23 PM
geozukigti geozukigti is offline
yeah, i burnt up a 3cyl engine head in 2 weeks by blocking off the EGR on it. Try spraying some de-carb up in the egr valve, and in the lines that go through the head. It could be all plugged up with carbon, and giving false readings to the ecu.
Old 10-20-2003, 07:44 PM
Re: egr problem
You were 100% right! I removed the EGR, and the 2 large ports had some carbon buildup, about 50% plugged, but the middle size tube was 100% plugged. Scraped them out, and now I get flow, and no more Check Engine light (at least so far). Thanks for the info.
dMb
Logic is all
Old 10-24-2003, 10:19 AM
anytime
EGR replaced but engine light still comes on code shows EGR problem. RobDDDD Impala | Impala SS 2 10-16-2008 08:53 PM
1994 gmc egr problems need help blackhawk5177 Sierra 2 12-14-2003 09:24 PM
2000 F150 EGR Problem? FastCat F Series 0 11-07-2003 07:40 AM
1994 LeSabre EGR Problem ront LeSabre 6 11-06-2003 12:43 PM
1995 GA SE, 3.1 EGR Problem craz-e-e Grand AM 1 11-06-2003 06:18 AM
