Old 04-10-2012, 02:13 PM
trinfinate trinfinate is offline
1996 Mecury Sable Mods
Hello every one....hello shorod....i wanted to check if there is any bodykits for a 1996 mercury sable....or do 1996 fourd taurus body kits fit a sable?.....also would 18 inch rims fit on my sable?.....thank u guys...thank u shorod...u helped my tranny probem...and u helped a guy out with his dpfe sensor which i read about and helped me...lol...thanks
Old 04-10-2012, 10:45 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 1996 Mecury Sable Mods
You're welcome on the prior help. I don't have really anything to offer you on the body kit or wheel question. If you size the wheels and tires correctly, yeah, they will fit, but you will want to work with someone who knows which sets will fit. You need to get the correct backspacing and tire profile to ensure they don't rub.
-Rod
Old 04-11-2012, 04:44 PM
65comet's Avatar
65comet 65comet is offline
Having been rear ended in my 98 sable (same bumper as 96) and it messed up everything under the bumper except the outer shell, I took a taurus apart in the junk yard and discovered they are in fact very different. So you can't use the rear. The sides are exactly the same, so that is ok. The front depends on if you are going with an attachment to the bottom, or a replacement for the front. An attachment is ok, but with a replacement you will have to go to the junk yard and get taurus lights and mounts, grill insert etc. because they are not interchangeable.
1996 mecury sable Transmistion trinfinate Taurus | Taurus Wagon 6 03-13-2012 04:38 PM
1996 mecury sable trinfinate Sable 0 02-28-2012 02:14 PM
Pulling Motor 97 Mecury Sable bigdog46176 Sable 1 03-18-2008 06:22 PM
94 Mecury Sable, I think it has a bad motor mount... spunger Sable 2 07-22-2006 12:29 AM
