Go Back   Automotive Forums Car Chat > Ford > Tempo | Topaz
Old 04-01-2012, 12:23 AM
fomoco1912 fomoco1912 is offline
how to time a 1989 2.3L tempo engine?
I would like to know where are the timing marks on a 2.3L tempo engine or how can I time it if I know where top dead center is ? Also what is the gap on the spark plugs?
Old 04-01-2012, 01:29 AM
tempfixit tempfixit is offline
Re: how to time a 1989 2.3L tempo engine?
quote(
Timing is checked by using a timing light that triggers in relation to spark firing. This flashing light in turn is then pointed toward timing marks on the exterior of the engine to determine relative timing condition. The timing is advanced or retarded by turning the distributor. This turning of the distributor effects the rate at which the spark plugs fire. The timing marks on gasoline Tempo/Topaz engines can be found on the harmonic balancer/crank pulley, located on the right side of the engine, as well as through a hole on the transmission case. Before attempting to adjust the engine timing, make sure these timing marks are clean and easy to read.) quote
  1. NOTE: The correct spark plug gap is 0.039–0.043 in. (1.0–1.09mm)
i got this info from my local library website that has EBSCOHOST with ARRC( Auto Repair Reference Center ) check your local library.
You could also register at www.autozone.com for the repair guides, it is free also.
Hope this helps
1996 Ranger 2.3L Code P1443 sea-doin-it Ranger | Courier 3 03-07-2009 11:56 PM
WTB: 2.3L Mustang Engine outerlimit Classifieds 3 01-29-2007 08:22 AM
1993 2.3L LX Engine Problem outerlimit Mustang Problem Diagnosis 2 01-28-2007 04:05 AM
92 grand am 2.3L SOHC engine mount GrandAmNot Grand AM 36 10-24-2006 09:35 AM
2.3L Turbo engine swap in a 88' Ranger rezdog_420 Ranger | Courier 2 02-26-2005 02:54 AM
