Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-30-2012, 02:39 PM
v6camryturbo v6camryturbo is offline
need help ! idle air problem
hey guys i have a serious problem. i cleaned my iac valve to get rid of the sluggish idling. i turned the key and the kept reving. all the way to 5,000 rpms ( thats when i shut the car off) please help dont know what to do
Old 03-30-2012, 02:48 PM
Re: need help ! idle air problem
i also cleaned the egr vavle and it is disconnected from the intake port is that an issue?
Old 04-08-2012, 08:07 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Year, engine type, and mileage always helps. But in general, everything needs to be reinstalled for the engine to run properly.
The IAC valve is electrically actuated, so if you sprayed cleaner into the electrics, they could become damaged. Also, if you tried to compress the pintle then that can damage the little engagement teeth inside as well.
The EGR valve is a vacuum-operated diphragm so check to be sure that the connections are airtight and that the valve operates normally by applying vacuum to the ports. You can also check for leaks while the engine is running by spraying carb cleaner at all of the vacuum connections and around the TB. Any change in engine RPM points to a leak where you sprayed.
Finally, check that the throttle cable and butterfly valve in the TB isn't stuck open.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Idle Problem shortly after starting - Need help ASAP jp72 LeSabre 1 02-16-2011 03:38 PM
Idle air problem, 99 civic Shinobi_jak '96-'00 Civic 2 09-05-2007 10:51 PM
Need Help- Idle Problem booboo3604 Celica 2 03-01-2007 09:18 AM
Need Help- Idling Problem on Avalon??? Wilson C Avalon/Pronard 2 06-28-2006 01:06 PM
Need help...idle problem Soleman20 Maintenance 2 03-04-2002 05:38 PM
