Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 07-21-2007, 12:56 AM
Shinobi_jak Shinobi_jak is offline
Send a message via Yahoo to Shinobi_jak
Question Idle air problem, 99 civic
Hi everybody, I have a 99 Civic EX, and I have a little problem with it that I wanted to get other inputs on. Here is the full description of what’s going on.
My check engine light is on and I get the P0505 code from the diagnostic tool, which if I am right, is an idle air control problem. If rev up to about 1,500rpms they starts to fluctuate up and down. If I continue to rev higher it normalizes until I get to about 3,500rpms, at which point it starts to fluctuate again. When this happens as I’m driving it will just pull or bog a little when I shift gears.
What is weird about it is that if I reset the code it will run fine for a day or two until the light comes on again. However, sometimes even when the check engine light is on it runs fine.
I did do some research here on the forum and looked through some posts and it led me to the idle air control valve, cleaning that didn’t do anything. I also read somewhere that you can test the valve simply by unplugging it while it is on and it does seem to be on.
Has anyone had a similar problem? Thanks in advance, all responses are appreciated very much.
PS: Sorry for writing so much, it is just out of concern for my car.
Old 08-20-2007, 07:28 PM
240slider's Avatar
240slider 240slider is offline
Re: Idle air problem, 99 civic
I cleaned my ports inside the throttle body too. because air passes through there as well. also how is your pcv valve .I changed mine and the idle fluctuating stopped .
Old 09-05-2007, 10:51 PM
oxjam oxjam is offline
I had same problem. Pull back the rubber around wires going to idle air control and the wires are probably rotted away like mine. I still am having all kinds of other electrical problems I have not figured out.
