Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 06-28-2006, 09:25 AM
Wilson C Wilson C is offline
Cool Need Help- Idling Problem on Avalon???
Here's the story-
I took my Toyota Avalon in to a Goodyear tire and service center last week to replace the tires, check all fluids/top them off/change if necessary, and check my brakes. Before I took the car in, it never had any problems idling. When I got the car back, it started at first, but then immediately stalled. I tried a few times and the same thing happened, however, I figured it was just a temporary thing and would go away. Turns out, the car will not idle at all any more! So, I took it back to get them to fix the problem, since it seemed highly likely that they caused the problem, whether on accident or on purpose. However, they recommended an engine diagnostic and then came back with a quote to replace the throttle position sensor, do a decarbonization, and replace the fuel filter...does this seem fishy to anyone else, or do you think it is just a coincidence?
Thanks, Wilson
Old 06-28-2006, 10:44 AM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool Re: Need Help- Idling Problem on Avalon???
Clean your IAC, throttlebody, and EGR valves by hand. It's a $5 project.
If it still won't idle, check for vacuum leaks.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
Old 06-28-2006, 01:06 PM
Thanks, I'll try that.
Wilson
