Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-27-2012, 11:23 AM
LorenzoV LorenzoV is offline
Unhappy Camry Starter Electrical Short
Hi,
I'm driving a 1998 Toyota Camry LE 2.2 4-cylinder.
I believe there is an electrical short in my starter. Recently as I was parking it I noticed the car was smoking. The ABS and battery lights went on an off sporadically and returned to normal. I parked my vehicle and when I opened the hood I noticed smoke originating from right underneath the starter. There was a strong plastic electrical burn smell. Before that occurred whenever I tried to start the car the only result was a strong click, I had to turn the key over several times and the car would finally start.
I had this problem a couple months ago. I took the starter out and had it tested and it was fine. When I reinstalled it there were no problems at all for a couple months. Can anyone help me figure out what this issue is? Is it a wiring issue with the wires connected to the starter? A friend told me it might be the alternator.
Any help or input is great appreciated, Thanks.
Old 03-27-2012, 11:46 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Camry Starter Electrical Short
The appearance of unexplained dashboard light behavior is normally a sign of alternator problem.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 03-27-2012, 07:04 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
The periodic no start condition sounds like worn contacts inside the starter's solenoid. This is a common problem for all Denso starters. You can varify this the next time it won't start by taping on the starter's solenoid while someone holds the key in the start position. If the starter now cranks, you have varified this common worn starter solenoid contacts problem. The contacts can be replaced without replacing the entire starter.
Read the article about 1/3 of the way down in this thread titled STARTER CLICKS DOES NOT TURN ENGINE for more information:
http://www.automotiveforums.com/vbul...d.php?t=424744
Mike
wiring short in sterring colum? danielgast46 F Series 5 03-23-2009 07:35 PM
Electric Short due to penny falling into ciggy lighter tpfkatt Avalon/Pronard 5 05-11-2004 12:14 PM
Electrical short ? genetracewell Taurus | Taurus Wagon 0 01-13-2004 12:27 PM
electrical short ohcysp Metro 1 09-28-2003 11:12 PM
electrical short problem soundwave3100 Malibu 1 08-20-2003 08:39 PM
