Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 12-23-2003, 11:54 AM
tpfkatt tpfkatt is offline
Unhappy Electric Short due to penny falling into ciggy lighter
I dropped a penny into the cigarette lighter and it proceeded to make my stereo and side mirrors stop functioning. How do I fix this?
Old 12-23-2003, 03:55 PM
csaxon csaxon is offline
Re: Electric Short due to penny falling into ciggy lighter
Check the fuses.
Old 12-23-2003, 05:55 PM
Which fuses?
I see two small fuses boxes in the front right of the engine bay to
which these fuses are poorly marked and the map-guide doesn't
provide much more information than a few letters.
Old 12-26-2003, 09:42 AM
Check in the drivers side footwell above the pedals.
Old 04-05-2004, 01:29 PM
vandrakes vandrakes is offline
Send a message via AIM to vandrakes
Angry Electrical Problems in 95 Avalon
I don't think I dropped anything in the lighter, but here's what we've experienced since buying our 95 Avalon a year ago. Within a week, the motor that powers the antenna went out. Our "fix" was to put it in the "up" position then disconnect the motor. A week or so after that, the driver's door electronics for the car's electric windows stopped working. The motor in the door needs replacing. A couple of months later, horrible grinding noise in the steering and a fluid leak; replaced rack-and-pinion steering (apparently at least the second replacement on this car, and we now know it's a common malady). Then a few months ago, the fan became intermittent. Lost the radio, then the fan is off more often than it's on. This morning I got in the car; no clock/temperature/AC/fan/mirrors. Unbelievable. I've owned Toyotas my whole life (9 so far, new and used) and have NEVER had a lemon like this. I've checked all the fuses, so do I have some pervasive electrical short that's going to disable the car completely any minute? Someone please help; otherwise it's going to cost thousands to repair! Thanks!
Kathy
Old 05-11-2004, 12:14 PM
Vandrakes, has someone added aftermarket electronic equipment to your vehicle? If it's a used car maybe it was removed, but I suspect a possible hack job in the wiring that may be coming apart or shorting out. Have you already been fixed?
It worked fine until I fixed it!
