Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 03-21-2012, 09:12 PM
fantastic's Avatar
fantastic fantastic is offline
How to Change Spark Plugs 2007 Elantra
This is my "How To" on the spark plugs.
Tools:
-Ratchet 1/2"
-5/8 spark plug socket
-10mil socket
-New spark plugs
Here are the plugs I used
This picture shows the plastic cover over top of the engine and where the plugs are. There are 4 bolts that hold the cover to the engine. I've marked where the bolts are with arrows. I used a 10mm socket on these bolts to remove them. Once gone the cover lifts right off.
Now you can see the the plug wires and where the plugs will be.
Here is a pic of removing the plug wire. As you can see the length of the connector is bigger then you would expect (or at least I thought that)
Now take your 5/8's plug socket and begin to remove the plugs. I did one at a time so I didn't mess up any plug wires.
Here's a pic of the old and new side by side... Glad I changed them!!
Now, this is the last plug. You'll have to remove the plug wire from the distributor. Its not long enough to allow for the plug end to come out of the shaft.
As for tightening the new plugs on the box of the new plugs it showed 1/2 to 2/3 turn once snug. I chose 2/3 and didn't have to crank on it(DON'T BREAK THE PLUG!!)
After they're all in, reverse the first steps and you're done.
Any questions?? Just ask
Here's another FYI: REPLACE YOUR CABIN AIR FILTER!! The directions are in the car manuel. I replaced mine after changing the spark plugs.
Here is what my cabin air filter looked like. A new one is all white and won't have bugs in it LOL
Old 03-21-2012, 11:35 PM
TBrand57 TBrand57 is offline
Re: How to Change Spark Plugs
My hats off to you sir! This can be quite handy.
Old 03-24-2012, 08:38 AM
lowsonoma1999's Avatar
lowsonoma1999 lowsonoma1999 is offline
Authorized Vendor
Send a message via AIM to lowsonoma1999
Wrong plugs. The 2007 is supposed to have an iridium or double platinum plug in it. The factory Champions you pulled out are a double platinum.
John Nance
Parts Manager
Terry Lee Hyundai
17665 Terry Lee Crossing
Noblesville, IN 46060
Old 11-16-2012, 10:53 PM
fantastic's Avatar
I don't remember getting notified of your reply and thats why its so late...
Although they are supposed to be ir or dbl plat, copper can still be used. I'm not an expert but won't the difference between all of them be in the life span? (2-3 times longer life for ir and plat vs copper)
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
How do I change spark plugs? 1534dover Park Avenue 8 06-16-2005 07:30 PM
how often change spark plug wires? dderolph Integra 10 05-31-2005 03:18 AM
how to change spark plugs on 94 caravan elmofwd Caravan | Voyager 9 01-27-2005 07:02 AM
How to Change spark plugs? Jenean Elantra | Avante 2 09-02-2004 06:57 PM
