Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-03-2004, 08:09 AM
dderolph dderolph is offline
how often change spark plug wires?
Son has a 92 Integra GS with 152,000 miles on it. Looks it still has the original wires. Although we see no specific evidence they need to be changed, he thinks they should be replaced. Interested in any advice on this.
Old 08-03-2004, 12:48 PM
SBallerk2 SBallerk2 is offline
Send a message via MSN to SBallerk2
Re: how often change spark plug wires?
well they should be replaced every 12k...so around every 15k I would SAY....but no MORE THE 15k...
also u can buy Stock one's so they might of replaced them with stock one's....
PRELUDE's
Old 08-03-2004, 01:17 PM
integrasedan integrasedan is offline
check the wires with a digital ohm reader, or whatever they're called, to find out their resistance.
With that many miles I bet new ones will make the car run smoother, but no spark plug wires make horsepower, unless your old ones were pretty worn out.
Old 08-03-2004, 02:00 PM
SBallerk2, thanks for the reply, but I have to disagree with you. The interval you suggested is just not necessary. My son bought the car when it had about 90K miles on it. He has never changed plug wires and, as I said, the car seems to be running OK. Also, since starting this forum thread, I've read some info on two web sites, one recommending new plug wires every time spark plugs are changed, and the other, which happens to be a web page of Advance Auto Parts, suggests "Generally, at the manufacturer's recommended tune-up intervals where the plugs are replaced, or at five years (60,000 mile tune-up) or seven years (100,000 mile tune-up), even when the plugs don't necessarily need to be changed due to age alone."
The manufacturer's recommended interval for replacing plugs in this car is 30K miles. Regarding "Ignition Wiring", the owner's manual says Inspect it every 60K miles.
I wouldn't be surprised if these wires are the originals. They have the cylinder printed on them, when is a sign of OEM wires. Of course, the originals could have been replaced with OEM wires.
So, sure looks to me like the wires need to be replaced no more often than 60K miles.
Old 08-03-2004, 02:06 PM
integrasedan, your suggestion to "check the wires with a digital ohm reader, or whatever they're called, to find out their resistance" is probably a very good approach. We don't have that tool, and I don't know whether we'll buy one, but I think I'll see how much they cost and find out more about how to use them.
Old 08-03-2004, 05:44 PM
boosted k20's Avatar
boosted k20 boosted k20 is offline
u can get a multimeter (ohms, volts, current) at radio shack
www.MEDIUMRACING.com
Old 08-03-2004, 06:00 PM
OK, thanks. I believe those multimeters can be used for testing other electronics, too, right? Will check it out.
Old 05-28-2005, 03:26 AM
drm95 drm95 is offline
what is a good kind of spark plug wires to get?
Old 05-30-2005, 11:38 PM
spaminator's Avatar
spaminator spaminator is offline
Send a message via AIM to spaminator
Nology hotwires are the best. I put them on my 91 recently and it runs smoother. of course at $150 itebetter work right. Expensive bastards
Horsepower is how fast you go into the wall. Torque is how much of the wall you take with you.
Originally Posted by YogsVR4
Everyone gets only one birthday anyway. We come out and about half of us spend a good portion of the rest of our lives trying to get back in.
Old 05-31-2005, 12:55 AM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
omg, just replace the wires. they cost like $30. what are u being a multimeter for...
http://cgi.ebay.com/ebaymotors/ws/eB...category=33692
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 05-31-2005, 03:18 AM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
I'd definately suggest replacing the wires and plugs. If they're OEM parts, then they could have been replaced w/ OEM's, but even still, the car just topped 150k, and so it wouldn't be hurting anything. (better safe than sorry eh?)
IMO, don't waste your money on expensive wires, just got out and buy either the OEM ones, or a $30-40 set from a local shop. The car isn't going to see any gains from a more expensive wire, so why waste the money?
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
