Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 03-19-2012, 06:24 PM
Zeifer Zeifer is offline
Bumping Up The Rev Limiter?
Hey guys, how would I go about raising the rev limiter up to 7k RPM?
I have an '01 Cavalier with a 2.2.
I know these are pretty durable engines, so what precautions would I need to take before bumping the rev limiter up (if any)? I'm replacing the head gasket once I get paid because it's starting to leak.
Is there any benefit to doing this, or does the power/torque curve die past the 6.4k point?
Thanks for the help.
Old 03-19-2012, 06:44 PM
Tech II Tech II is offline
Re: Bumping Up The Rev Limiter?
You can't...the rev limiter is built into the programming of the
PCM....
Old 03-19-2012, 06:45 PM
PCM....
Actually in a post (I think relating to the removal of the 108MPH speed limiter), CRJ stated his rev limiter was set to 7k.
Old 06-03-2012, 03:24 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Yes, he did. hptuners.com is where you can get the software to do this
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 09-05-2012, 09:03 PM
J-Ri's Avatar
J-Ri J-Ri is offline
If you would be purchasing HP tuners specifically to raise the rev limiter, not worth it. If you're already tuning it, go for it.
Mine has the Ecotec, so this may not be extremely relevant... I have mine set at 7,200 RPM, but the power does drop off noticeably at about 7,000 RPM. I left the extra in there just so I don't have to worry about bouncing off the rev limiter. It's nice to be able to go a bit higher, but not worth paying for, IMO.
It's also worth noting that mine is supercharged, so it's possible that yours may have some added ram-air effect since you have intake runners and I don't. It's also possible it may starve for air.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 09-10-2012, 11:49 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
On that engine, kiss your head good bye without head work, stronger valves and stiffer springs, roller rockers...
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Riding the Rev limiter clawhammer '88 - '91 Civic | CRX | Wagon | Shuttlee 11 10-05-2005 11:18 AM
the rev limiter invinci88 Thunderbird 1 08-26-2005 11:26 AM
what year was the rev limiter lowered? thechad25 Celica 1 01-19-2004 10:52 AM
removing the rev limit chriztofer Engineering/ Technical 14 12-20-2003 01:34 PM
How to move the rev limiter??? 910Bluebird Performance 2 08-06-2002 09:08 AM
