Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 03-18-2012, 05:01 PM
tnw83 tnw83 is offline
91 Olds 98 wont stay running
I have a 91 olds 98 regency elite. After reaching operating temp the engine starts stalling. It will restart and go and shut off again. The warmer it is outside the quicker it does it. It also starts flashing hot yet not overheating. I have replaced the ignition module, the coil pack, the crank sensor, the cam sensor, the fuel pump and the thermostat. I am at a loss and desperately confused.
Old 03-18-2012, 06:27 PM
maxwedge maxwedge is offline
A990 racer
Re: 91 Olds 98 wont stay running
Welcome to AF, does it start right up, does it stall driving or at idle.
Old 06-21-2012, 02:35 PM
greyhouse greyhouse is offline
Did you get this figured out? I am having the same problem with my 92 regency
Old 06-22-2012, 11:00 AM
Tech II Tech II is offline
When your's stalls, does it restart right away, or do you have to a wait a few minutes?
Old 01-30-2013, 01:09 PM
snow1snow1 snow1snow1 is offline
I have a 95 olds 98 regency with a 3.8l doing the same thing. I get code p0342 Camshaft sensor intermittent failure. It is like you just turned the car off. It won't start until you turn the key off then it will fire right up.
Old 01-30-2013, 07:38 PM
A990 racer
8 month old thread you may not get any responses. The cam sensor will not cause stalling, it my be hard to start at times, you have something else going on, post a better description of when and how this ocurs, 91 and 95 are different systems.
Only runs with key in the START position AMAMEK9 Eclipse Problem Diagnosis 6 03-12-2011 07:47 PM
wont stay running rlm296 General Discussion 1 06-11-2004 07:23 PM
1992 cherokee wont stay running RalphJr5051 Cherokee 1 04-03-2004 03:35 PM
Car wont stay running! Help ! Xdemise Mustang Talk 1 08-03-2003 11:28 PM
2000 Z71 wont stay running 99silverGT Tahoe 8 07-13-2003 08:54 PM
