Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-22-2009, 10:44 PM
AMAMEK9 AMAMEK9 is offline
Only runs with key in the START position
I have a 1991 Mitsubishi eclipse, its a 5 speed, and although it probably isnt a mitsubishi only problem, i still would like some help...It will start and run just fine if the key is held in the START position, but as soon as you let the key rotate back the the ON position, it losses power and dies. Any ideas???
Old 03-23-2009, 09:03 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Only runs with key in the START position
Welcome to AF!
So basically the car only runs when the starter is cranking it? Is the car actually firing and delivering fuel?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-21-2009, 11:26 AM
CADMAN68 CADMAN68 is offline
I had a civic that had the exact same problem it would only run if you held the key in the start position or just a little less than the start position, let it go to the on position and it would quit on me. I replaced the ignition switch and never had any more trouble with it. Could be your ignition switch has gone bad......just a thought.
Old 05-21-2009, 05:57 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I would bet on ignition switch as well
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-12-2011, 11:02 AM
thepeggasus thepeggasus is offline
I have already replaced the ignition switch on this vehicle. I replaced the ignition switch on my daughter's car approximately a month ago as the finger turn had broken free and she was in danger of breaking the key off in the switch. The car has been starting and running fine. She called me last night as the car will start but she has to back off of the start position slightly and hold it there for it to run. It will not run in the run position. Is there a fusible link, fuse, circuit breaker that could cause this or is the explanation simply that the new ignition switch (as unlikely as that sounds) has gone bad?
Old 03-12-2011, 07:33 PM
Decided to buy my daughter another ignition switch - the unthinkable DID happen. The switch I purchased just a month ago HAD failed. Installed the new switch and her car is running again.
Old 03-12-2011, 07:47 PM
inafogg inafogg is offline
good to hear
but its always good to stay oem
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Tags
ignition , mitsubishi , starter , wont stay running
