Can someone telle how to straight wire the switch on the ac compressor to make the clutch engage my ac quit all of a sudden an I noticed that it was not kicking on just free spinning and I wanted to make sure it wasn't some switch or relay causing that before I buy a new compressor ? Thanks
Re: 96 Taurus ac compressor
There is a high pressure switch and an low pressure switch. The purpose of these are to protect the compressor in the event of either a high or low pressure situation. Shorting around either of these switches will not tell you if the problem is with a switch, putting a gauge set on the high and low pressure lines will at least tell you if the pressure levels are correct to where the switches should be closed, then you can use your multimeter to determine if the switches are closed. If so, your problem lies elsewhere. If the pressures are good but one of the switches is reading open, then, and only then, should you consider bypassing the switch to see if the clutch then engages.
-Rod |
65% of mobile a/c failures are due to loss of refrigerant, due to a leak....I'd put a gage set on it and see what your static pressure is-- if not above 50 or so psi (at 70 degf ambient) then you have lost 95% of your refrigerant.
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
