Old 05-19-2009, 12:00 PM
pete029 pete029 is offline
Send a message via AIM to pete029
Question 95 Lumina A/C Compressor Noise
I am wondering if I have a problem with my a/c compressor. I recently added some r-134a because the a/c has been non-existant for about a year. I used a decent quality gauge to check the pressure and it isn't overfilled or anything. Anyway, after I did this I noticed that the compressor would make a high-pitched grinding noise (bad bearing??). I have heard this noise before, but I was able to pinpoint the source of the noise while I was dealing with recharging the refrigerant. The thing that puzzles me about the noise is that it only occurs when I turn the blower fan motor OFF or if the a/c clutch is disengaged. When the fan is ON and the compressor clutch is engaged, then there is no noise. Does anyone know what the deal is with this and if I should be concerned? I was thinking that it might go away over time, but I don't know (I just recharged the a/c a week ago and haven't used it much).
Old 05-19-2009, 03:28 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 95 Lumina A/C Compressor Noise
Originally Posted by pete029 View Post
. The thing that puzzles me about the noise is that it only occurs when I turn the blower fan motor OFF or if the a/c clutch is disengaged. When the fan is ON and the compressor clutch is engaged, then there is no noise. Does anyone know what the deal is with this and if I should be concerned? ).
This sounds like classic v-5 clutch drag- the air gap has tightened (due to corrosion) and needs to be adjusted back to .020" . I have answered this several times- and usually see about 1 a week during the hot season. The noise is a scrapping/rattle only with a/c off- should see signs of metal shavings about the clutch hub. The fix is to borrow the installer/removal tool from autozone and back off the air gap a tad. This can be done on car, without removing compressor or refrigerant, and can even be done without removing the shaft nut since the nut does not bottom on the clutch drive. Pull back the plastic cover in wheel well to access
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Tags
a/c , compressor , lumina
