Old 01-17-2011, 12:40 PM
HBTaurus2005 HBTaurus2005 is offline
2005 Ford Taurus Siezed A/C Compressor
I have a 2005 Ford Taurus and the a/c compressor siezed and the serpantine belt snapped last week. I took it to a shop and they said there is no way to bypass the a/c compressor and there is no one that makes an after market bypass pully for this model.
My question: Can I bypass the A/C compressor on the 05' Taurus with a shorter serpantine belt? If yes, what length should it be? Is this a reliable solution?
Old 01-20-2011, 11:05 PM
Willyum Willyum is offline
Re: 2005 Ford Taurus Siezed A/C Compressor
Can't you free up the pulley and let 'er spin?
Old 01-21-2011, 08:27 AM
mark_gober mark_gober is offline
They do exist. I've never done it, so I'd be lying to you if I told you how to do it. You could measure the distance with a tape measure, purchase two or three that are close and just return the ones that don't fit. Just make sure that you don't mess up the routing. (I've done this and it fit right on there, just turned one accessory the wrong direction.)
http://www.partspros.com/7001628.html
Mark
Old 01-21-2011, 12:29 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
For your question, it depends if you have the OHV or the DOHC (duratech) engine. If you have the DOHC, you can't bypass the compressor with a shorter serpantine belt. But you can remove compressor and use the Bypass Pulley in the Mark's link. And use OEM or other brands belt for this car.
If you have the OHV (vulcan) engine, you can bypass the compressor with a shorter belt. But I don't know the lenght, since all stock 96-today taurus come with A/C as standard. So you can use Mark's trick to find the appropriate belt for it.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 10-17-2011, 06:59 PM
MrBala MrBala is offline
The advice from serge_saati Worked for Me. I purchased a Prestone serp belt Part #825K6
Thanks
Old 06-19-2014, 01:29 AM
Rpetty10 Rpetty10 is offline
The A/C on the DOHC CAN be bypassed!!! I did it.
I bought the belt at Oreilly. The receipt says the part # is
MBH K060630 Micro-V belt for &15.99. Just route the belt in the red area i have added in the diagram instead of the A/C. You will notice that the ribbed side of the belt touches the smooth water pump pulley now, but this will not hurt anything. The auto parts stores only tell you it cannot be done because they do not show a diagram for these cars WITHOUT A/C like some older cars would show. It is possible. Go try it, and drive another 100,000 miles!
The Following User Says Thank You to Rpetty10 For This Useful Post:
PeRshGo (06-19-2014)
Old 06-19-2014, 04:37 PM
PeRshGo PeRshGo is offline
Thumbs up Re: 2005 Ford Taurus Siezed A/C Compressor
Thanks for the info on the part! For whatever reason though I cannot see your diagram. Would you mind trying to post it again?
Thanks.
Old 06-19-2014, 05:06 PM
Not sure why it's not working. I'm not at my computer right now. Basically you just route the belt from the crankshaft Pully up and over the water pump, then on its regular path the rest of the way. Look at your belt diagram under the hood, and just bypass the ac.
Old 06-19-2014, 05:40 PM
The DOHC diagram doesn't list a water pump.
Old 06-20-2014, 12:28 AM
aleekat aleekat is offline
Under your hood?
Post back, that's what makes Forums Work.
Old 07-06-2014, 02:01 PM
mikek32 mikek32 is offline
Has any one figured this out rpetty10 i went and bought the belt and cant figure this out or how it would work. I have the 3.0 duratec any help would be greatly appreciated. Post that diagram if you can.
Tags
a/c , compressor
