Go Back   Automotive Forums Car Chat > Chevrolet > Prism
Old 03-01-2012, 10:01 PM
Pinky131969 Pinky131969 is offline
just bought a car with problems
I have a 2000 chevy prism. i drove fine for a week. then the check engine light came on. the mass air flow was replaced with a brand new one. then, a week later, another code is showing that the car needs a new catalytic converter, because the check engine light came on again. my question is what symptoms are apparent with this problem of needing a new catalytic converter and also will it die on me driving long distances? it should be fixed next week under warranty.
Old 03-02-2012, 07:30 PM
82Stang 82Stang is offline
Re: just bought a car with problems
Hi,
What was the code, the first and second one?
1)codes for these type things, involve alot of different causes
2) cats are pricey, so when you change one, you want to be sure
Symptoms of bad cats include, but not limited to: a rotten egg smell, low engine power, loss of acceleration power, engine overheating or cat getting hot/red hot visibly. If you get a good flow of air out the tail pipe, assuming the exhaust is intact, then that should signify it isn't clogged. Hold your hand over the tailpipe and it should build a little pressure.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 03-06-2012, 04:38 AM
Smile Re: just bought a car with problems
thanks for the reply. it turns out, i think i don't need a catalytic converter. it lost two quarts of oil. filled the oil to level suppose to be at, and the check engine light, went off. there are a few oil leaks. thanks for the reply.
Old 03-06-2012, 10:48 AM
Your welcome.
Rodney Dangerfield
Just bought - need a new engine, help! Kaeldra1 Focus | C Max 1 06-20-2010 07:43 AM
Just bought a 93 da with b20 block b16 head - have some problems!! knack knack Integra 0 05-15-2007 08:06 PM
how do I tell I have gt or gts?..just bought car kynchanted Celica 3 10-23-2005 11:57 PM
Help With 96 Avenger.. Just Bought.. No Manual PLEASE!!! Many Problems vMoNeY Avenger 6 08-19-2005 11:11 AM
just bought car, need electrical help, cooling fans dont turn on proud_924s_owner 924/944/968 3 01-19-2005 09:17 PM
