Old 03-01-2012, 01:32 PM
Circle Circle is offline
Hard Shifting
I've seen a lot of posts regarding rough shifts like my 99 GLS (93k mi.) suffers from. Can someone explain why this would happen only in warm weather and stop and go driving and not when the outside temp is less than 60 degrees?
Knowing the above my eliminate some causes which will occur regardless of temperature. I don't want to fix something that aint broke.
Thanks
Old 03-04-2012, 06:23 PM
dosintrigued's Avatar
dosintrigued dosintrigued is offline
Re: Hard Shifting
The problem relates to inconsistent operation of the pressure control solenoid, which affects shifting of the tranny. The colder temps allow thicker viscosity tranny fluid, keeping the shift more normal.
Once the temp comes up, the fluid will thin out and your problem will return. (Except during the first 20 minutes of operation while the oil is still coming up to temp.)
The Following User Says Thank You to dosintrigued For This Useful Post:
Circle (03-05-2012)
Old 03-05-2012, 07:46 PM
Re: Hard Shifting
Thank you for a really sensible answer.
I had to add some "universal" transmission fluid after my service guy left it short. You think a complete fluid change to the proper fluid for GM cars will make a difference?
Old 03-06-2012, 05:55 PM
Re: Hard Shifting
An oil change may help, especially if the current fluid is spent. I would recommend a bottle of Lubegard to go with it. That may loosen up some of the varnish deposits that may be contributing to the problem.
i_hate_cars38 (06-07-2012)
Old 03-06-2012, 09:10 PM
Tech II Tech II is offline
Re: Hard Shifting
Have the vehicle scanned for engine/tranny codes.....not all codes turn the light on....
Old 06-07-2012, 02:58 PM
i_hate_cars38's Avatar
i_hate_cars38 i_hate_cars38 is offline
Lost In The Darkness
Re: Hard Shifting
like said Lubegard dr tranny and tranny flush all by the same company can help But transmissions are meant to be dumped and new filter i think 60k other would know more i only got to engines in school and life try those and the other stuff the more knowledgeable people put in my tranny post
All the great things are simple, and many can be expressed in a single word: freedom, justice, honor, duty, mercy, hope.
Winston Churchill
The most difficult phase of life is not when no one understands you,
it is when you don't understand yourself.
«It's good to know that if I behave strangely enough, society will take full responsibility for me.»
Old 07-05-2012, 10:59 AM
msg44 msg44 is offline
Re: Hard Shifting
I read all of the forums and ignored my EXTREMELY hard shifting for almost a year. For me, it turned out to be the Mass Air Flow Sensor. Good luck.
Old 07-05-2012, 01:50 PM
Re: Hard Shifting
thanks so much with how old and miles i will see how much a mass is and also do the flush and filter change thes computerized cars are to much lik pcs one thing can cause a whole host of problems that seem like five possible answers i miss the 70s and 80s less computer and other fancy crap and no matter the engine you could hop on the fender and have tons of room to work and dangle your legs lol i also found out these stupid fancy electronic climate controls on these cars have no vent feature just ac my ac is dead so it 4 windows man i miss older shit
Winston Churchill
04 impala Shifts Hard when Hot, P1811,shifts hard,jerks chevymandan Impala | Impala SS 3 10-09-2011 04:42 PM
Please Help 95 Blazer shifting hard ryanusrey2012 Blazer 4 05-26-2011 09:53 AM
Gear selector hard to shift serge_saati Windstar 16 06-05-2009 09:57 PM
S-10 hard 1 - 2 hard shift joslinm Problem Diagnosis 5 03-09-2009 05:33 PM
95 sl hard shift and hard start wkmaylish SC/SL/SW 9 06-10-2005 12:53 AM
