Old 05-19-2011, 09:38 AM
ryanusrey2012 ryanusrey2012 is offline
Unhappy Please Help 95 Blazer shifting hard
hi i have a 95 blazer that i just had replaced the spider assembly on and once i had put everything back together it is hard to start and when i put it in gear it slams into gear and when going down the road it shifts really late and when it does it is kind of a hard shift. could this be a vacuum problem at all any suggestions will be appreciated
Old 05-23-2011, 09:51 AM
Re: Please Help 95 Blazer shifting hard
also i have a bad motor mount on one side could this be causing the hard jerking problem when i put it in drive or reverse?
Old 05-25-2011, 09:39 AM
anything, anything at all??? no one has any suggestions on here at all wow
Old 05-25-2011, 09:52 AM
NHRA's Avatar
NHRA NHRA is offline
check for vacum leak ..........hose
The Following User Says Thank You to NHRA For This Useful Post:
ryanusrey2012 (05-26-2011)
Old 05-26-2011, 09:53 AM
vacuum lines scope out fine. i have no readings tho i will get vacuum readings but it is less than likely this is my problem
96 Blazer Shifting Hard shanequale Problem Diagnosis 4 02-09-2008 11:10 AM
Help Me PLEASE My Neon Shifts hard kandy_k_46804 1st Gen 95-99 6 08-20-2006 11:16 AM
1998 Blazer Shifts Hard only 1st to 2nd???? Wildman98 Blazer 4 05-08-2004 11:30 AM
97 blazer shifts hard Invictus Blazer 1 02-16-2004 10:36 PM
1996 blazer shifts hard between 1st+2nd 30 pak Blazer 3 12-10-2003 10:49 AM
Tags
gear , hard , shifting , transmission , vacuum
