Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-23-2012, 02:18 PM
jrrtex99 jrrtex99 is offline
lack of power/stuttering
Hello all, I have a 1994 GT (5.0) convertible that has a overall lack of power and it runs rough in wet weather. It is mostly stock but it does have a Mallory aftermarket ignition system. I pulled over after running about 20 miles and notices that my headers were glowing, not brightly, but glowing. I was told this was because of a rich condition. Is this true and what should I be looking for? I recently replaced the fuel filter, it helped, but it still is running like we're pulling a trailer.
Old 02-23-2012, 04:55 PM
P_A_B's Avatar
P_A_B P_A_B is offline
Re: lack of power/stuttering
lack of power can be caused by many things. Like you said, fuel filter is one. The fuel pump pressure could be low. spark plugs could be the cause, exhaust system restriction, retarded cam or ignition timing, low compression, or accelerator not opening throttle all the way.
Do you hear a knock? if so the computer is retarding the ignition timing to reduce or eliminate the spark knock.
But to start, I would check the spark plugs and the fuel pump, and the throttle.
The Following User Says Thank You to P_A_B For This Useful Post:
jrrtex99 (02-28-2012)
Old 02-28-2012, 09:07 AM
Well i've narrowed it down a little, it runs bad when it's humid or raining outside.
1998 2500 7.4 lacks power jjs1234 Sierra 3 11-20-2004 08:43 AM
350 in a chevy g 20 van lacks power when air filter is on D_E_A_D General Discussion 5 03-06-2004 03:31 PM
'93 4.0 ranger lacking power resliss Ranger | Courier 1 01-02-2004 04:42 PM
'94 3.0L lacks power? truckgal Ranger | Courier 5 12-27-2003 09:31 AM
90 GP Lacks Power Chavo2005 Grand Prix 10 12-27-2003 01:39 AM
