Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 03-05-2004, 07:58 PM
D_E_A_D D_E_A_D is offline
350 in a chevy g 20 van lacks power when air filter is on
runs great when aie cleaner is off. but when i put it on and drive, it lacks power. also the choke seems difficult to move. PLEASE HELP!!!
Old 03-06-2004, 02:42 AM
Pleeease!!!!!
Old 03-06-2004, 07:43 AM
a1supersport a1supersport is offline
Send a message via AIM to a1supersport Send a message via Yahoo to a1supersport
Re: 350 in a chevy g 20 van lacks power when air filter is on
I'll assume you tried driving it with the air filter off? What position is the choke stuck in...closed, open, or in between?
Old 03-06-2004, 11:54 AM
yes i have drove it with the air filter off and the choke is stuck in the closed position. never opens unless i do it manually
Old 03-06-2004, 03:15 PM
amac209 amac209 is offline
Send a message via MSN to amac209
what kind of carb do you have?? q-jet does it have electric choke??? if it does loosen the adjusting screws and twist it towards the open position. also check the wire it might've popped off.
if you have one of those heat coil things bend the rod so it pushes the choke open more. also get some carb cleaner and give it a good shot might just be a little sticky. don't drive without an air filter or you'll need another motor. another thing to check is the TAC thats the vacuum valve thing with a pipe going in to it. good luck should be a simple quick fix
Old 03-06-2004, 04:31 PM
the carb is a rochester m4mc series.
