Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-04-2012, 12:51 PM
jerroldk jerroldk is offline
A/C Compresser Noise
I've read a few threads in this forum about similar conditions but did not find my exact scenario. I've got a 2000 Regal GS 3800 SC w/160K+ miles.
The other day the compressor suddenly began making a moderatly loud ticking noise. I know it is the compressor because the noise is only present when the a/c kicks on. When it kicks off the noise stops.
I also noticed, that when the compressor kicks off that it does not come to a complete and abrupt stop. It seems to stop, then for a second or so, skips/rotates forward once or twice about 1/16th of a turn. I've never looked to notice if this is normal operation or a sign of something going bad in the clutch. From above, visually I see nothing wrong with the compressor clutch.
I've been living without the a/c for a few days, but need to get it resolved. Is this pretty much a slam dunk that the compressor's clutch assembly or it's bearing needs to be replaced? How difficult is this job and are there special tools needed beyond regular pullers? Any links to this procedure? Thanks to all who can help.
Jerrold
Old 02-04-2012, 05:23 PM
brcidd's Avatar
brcidd brcidd is offline
Re: A/C Compresser Noise
Check the air gap between the pulley and clutch plate--it is probably near zero-- should be .020" . I'd say the clutch is too close due to corrosion behind the rivet head stops that don't allow it to retract fully- and it is rubbing when not engaged-- look for iron filings clinging to front of clutch to confirm rubbing- or use your feeler gauge to check air gap. The air gap can be adjusted by "borrowing" the tool from Autozone. Very common problem on V-5 compressors.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 02-21-2012, 02:00 PM
But what about the noise? It makes a ticking noise when the a/c is on or engaged. There is no problem when the clutch is disengaged. As far as the skipping forward of the clutch, I mentioned above, then yes I can agree that the air gap is minimal and could use adjustment, but this doesn't answer my question about the clutch bearing or it's replacement. Anyone else have any input?
Old 02-21-2012, 05:34 PM
DeltaP DeltaP is offline
Start savin up for a compressor,drier and O tube. She's gonna take a dump!
Old 04-02-2012, 06:19 PM
All I've not replaced the compressor yet, but will say I'm more convinced that it is just a bad compressor. I've been reluctant to use the AC since it started making noise and after a few weeks since it began it's grown louder and more severe when the compressor is engaged. Below I've added a link to a video for others to see and hear (please note I am manually switching the AC on and off so what is shown is not it's normal cycling.
https://picasaweb.google.com/1157871...39657171884514
Just wanted to ask a couple of other questions. Based off the the video does anyone think it may be something other than a failing compressor (like low refrigerant or refrigerant oil)? I ruled these possibilities out because the knocking has become so severe. Keep in mind the system still cools just fine.
Assuming it's a failing compressor, I know I need to replace the o-tube, dryer, and compressor. Any tips on how to do the flushing process? Anything else I better not forget? How much refrigerant and refrigerant oil should I add to the system on the recharge for this vehicle?
Old 04-02-2012, 06:25 PM
brcidd's Avatar
compressor has internal issues- like a broken reed valve or even a connecting rod- you will need to change it out..
'99 GMC Yukon
Silverado weird sound Silverado_Dude Silverado 10 11-13-2009 05:10 AM
2000 blazer 2 dr 4x4, loud humming noise and grinding noise MrEd002u Blazer 3 07-14-2004 12:09 AM
engine noise, sounds like lifter noise dwilkerson C/K 1 12-08-2003 01:59 PM
2003 Suburban: Poor brakes, front end noises gas pedal buzz, AC noise gsfitz C/K 1 11-20-2003 09:11 PM
dentist drill like noise & rattling noise 96LSIntegraRocket Integra 2 05-16-2002 11:50 PM
