Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Technical: How To... - FAQs
Technical: How To... - FAQs All How To's and Frequently Asked Questions.
Old 02-03-2012, 11:29 AM
FormulaForce FormulaForce is offline
1995 Formula, Fuel Pump Replacement
Hi Crew,
I'm selling my Formula, but it doesn't run because the fuel pump gave out, and no one will pay much for a non-running car. I'm familiar with the standard method of replacing the pump (drop the tank from the bottom) but there are apparently some people that have cut an access hole from the top using nibblers. I could try the tank-drop method, but I have to work alone in my driveway and have some concerns about getting the car high enough off the ground. Also, there is about 6 gallons in the tank that I can't get out. I've been trying to let it evaporate since I can't siphon it. Anyway, I'd like opinions on the cutting-the-hole method, and any links to do it. Please advise...
Old 02-04-2012, 04:48 PM
jamesslcx jamesslcx is offline
Re: 1995 Formula, Fuel Pump Replacement
Formula, I've heard of a lot of people doing it that way. Cutting a hole just above the pump and fabricating a cover slightly larger than the hole and bolting it on. If you seal it up good and hide it well it would work and since you are selling it anyway.
Old 02-04-2012, 04:49 PM
By the way I should say that this is not the recommended way to fix.
Old 02-04-2012, 09:38 PM
Tech II Tech II is offline
For the life of me, why in the world did GM use a solid fill tube welded to the tank, is beyond moi......maybe for safety reasons in a rear end collision? It's because of this, you need to really jack up the rear end for clearance.....never mind the problems with rusted fuel and evap lines.....
GM could have saved a lot of money on warranty repairs, if an access hole was intalled for the fuel pump, like they did with "W" and "H" cars....
I never tried it on an "F" car, but sounds like a good idea....
Old 02-05-2012, 04:07 PM
Tech II, I've always said G.M as well as others should have let the techs design their vehicles or at least been advisers, a lot of headaches could have been avoided.
Old 02-05-2012, 09:09 PM
Yeah, some of the things they do just make you shake your head.....
Old 02-06-2012, 08:05 AM
I think I'm going to try it. I found some really good videos on youtube about it. The metal over the tank seems very thin, and I don't think it plays much of a role in the car's structural integrity. I'm more concerned about the sparks from the cutting wheel (I'm going to use a Dremel tool for a cleaner edge than a nibbler, which I don't have anyway) but there shouldn't be any fumes in the area if the pump seal is OK, and I have no reason to think it's not. I might chicken-out and use tin snips. Hard to empty the tank when you can't siphon, and the pump won't turn at all. I swear, the same guy who designed the opti-spark distributor and it's wonderful location had to have a part in this fuel pump design.
Now to find a pump, local stores don't seem to have any in stock.
I'll try to remember to post my results. Thanks for the responses.
Old 02-08-2012, 01:39 PM
Never mind, I got an offer from someone willing to buy the car as-is. I would have tried it though.
No more F-bodies for me. Too much anguish. My next toy is going to have a highly exotic item called a carburator.
Old 02-08-2012, 04:14 PM
Formula, sound like a good plan! Best of luck.
2000 grand prix stalls jay44 Grand Prix 51 03-01-2013 08:10 PM
99 Cutlass GL - fuel siphoning before fuel pump replacement lockdoc70 Cutlass Series 2 10-28-2008 02:20 AM
1995 f-150 fuel pump replacement edith74 F Series 3 09-30-2005 07:00 AM
1995 Camaro Fuel Pump Replacement??? ripcity Camaro Discussions 5 12-03-2004 09:07 PM
p10/1995/G20 Fuel Pump part #? paradyme Maintenance 0 12-07-2001 01:00 AM
