Old 02-17-2009, 10:16 AM
jay44 jay44 is offline
2000 grand prix stalls
Old 02-17-2009, 10:18 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 2000 grand prix stalls
Welcome to AF
It would help to include the trim level and engine in your post.
Also, try to be a little more specific. Does it start then stall?, while driving?, coming to a stop?, randomly?,etc...
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 02-17-2009, 10:31 AM
2000 grand prix gt 3.8
Old 02-17-2009, 10:41 AM
randonly
richtazz's Avatar
I merged your two threads. In the future, keep all posts in the same thread for the same issue. Just click on the thread name, then scroll to the bottom to add your new info. thanks
On your issue, can you please be more specific as to how the car stalls (at start up, randomly while driving, when coming to a stop, etc...). Also, when it stalls, does the tachometer drop to zero and the trac-off light come on just prior to stalling?
Old 02-17-2009, 11:18 AM
trac light does not come on
Old 02-17-2009, 11:21 AM
changed pump filter and relay
Old 02-17-2009, 11:25 AM
richtazz's Avatar
Do you have a service engine light that remains on when the car is running? If so, have you had the codes pulled?
Old 02-17-2009, 11:35 AM
engine light does not come on. Its just dies and the only lights that come on are the oil light and battery light
Old 02-17-2009, 12:09 PM
need help
Old 02-17-2009, 12:13 PM
richtazz's Avatar
I would suspect a crank position sensor, but since you say you get no tachometer drop to zero or trac-off lights (which almost always accompany a bad crank position sensor signal) I couldn't say . I'm sorry, but your symptom explanations couldn't be more vague, which makes it virtually impossible to narrow it down.
Old 02-17-2009, 12:18 PM
while driving it dies, no service light or trac light. wait a few seconds it will start back up and drive. eventually it dies again.
Old 02-17-2009, 12:20 PM
had a fuel pressure test done, when car is started,pressure dropped to 40 psi. thats when i changed the pump and filter. car still dies
Old 02-17-2009, 12:28 PM
richtazz's Avatar
When you first turn the key on before starting the car, does the service engine soon and other warning lights come on then go off. They should, as the car will do a bulb test at key on). If not, your Service Engine light bulb may be burned out or missing.
does it die even when driving at a steady speed, or only when accelerating/decelerating?
Old 02-17-2009, 12:33 PM
service engine light does come on at start, so it appears to work. the car will die while driving at any speed, and at idle. the tach is fluctuating at idle between 600 and 1000 rpm
Tags
replaced fuel pump , replaced fuel pump filter
