Old 01-27-2012, 05:35 AM
Disca92's Avatar
Disca92 Disca92 is offline
Harley Samurai Chopper
Starting a new project before finishing the guzzi..
This time the model kit is the same of the FLH just posted (Academy 1/10 Harley).
What is a Samurai Chopper?
It's a strange bike: is a motorcycle with a strange long wheelbase, the height from the ground by fear and a line as low as a few..
You can see more at http://www.zeroengineeringeu.com/bikes/index.html
So I started wih the frame which I modified making it rigid (without rear ammo)
I scratchbuilt like the 70% of the frame using brass, plasticard and sprue parts.
Then I would have the open primary belt, so I scratched a new clutch (using plasticard, a washer and the hub of a formula1 wheel) and the corrispective pulley (using a tube's cap of cream).
Old 01-27-2012, 08:14 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Re: Harley Samurai Chopper
This is a very, very cool bike to make a model of. I can't wait to see what you do!
Old 01-28-2012, 02:18 PM
Disca92's Avatar
I scratched the primary belt using 3 layers of self-adhesive vinil for the body an 3 layers of vinil for the teeth
Old 01-28-2012, 04:06 PM
Disca92's Avatar
I built the oil tank, the fuel tank and the rear fender from scratch
Old 01-29-2012, 05:52 AM
ketje's Avatar
ketje ketje is offline
Hi, the built is looking great this far. Can you show me wath this kind of vinil is and how that you made the teeth on it? Did you place these one by one on it?
Thanx
Old 01-29-2012, 06:25 AM
Disca92's Avatar
Thanx
Ciao ketje! that vinil is simply the electrician's tape.. I stacked three layers of tape for the main body, I then stacked three other leaving a sticky surface and cutting off an infinite number of small teeth glued one by one on the body..
A lot of patience is needed especially for the correct distance between them but the work pays off.. As the last thing I cut the tape to the right width (7mm) and I brushed a drop of glue on the sides to make sure that the teeth were not moving on the body..
Old 01-29-2012, 08:58 AM
lovegt40's Avatar
lovegt40 lovegt40 is offline
ItaloSvensk
Too nice to read u also here.Your works are always too cool.
Will follow also this one, disca.Kepp on postin!
Paolo - LoveGT40 Modelworks
website www.alsoldatino.com
my YT channel : https://www.youtube.com/channel/UCIp..._as=subscriber
FB: https://www.facebook.com/alsoldatino
Old 02-02-2012, 05:48 AM
Disca92's Avatar
I modified the frame giving it the typical gooseneck frame shape..
Old 02-05-2012, 04:29 PM
Disca92's Avatar
Today I scratched the seat and the exhaust using aluminium, steel and plasticard..
Old 02-05-2012, 05:23 PM
M.Boy's Avatar
M.Boy M.Boy is offline
Great job!
Will be another interesting machine.
WIP: Custom CUb F100 Ducati 916 STUNT YAMAHA
GALLERY: VW Ducati 916 Custom CUb
Mark
Porsche 935 Tamiya 1/12 with Scale Motorsport Super Detail Kit FOR SALE
Old 02-07-2012, 05:14 PM
Disca92's Avatar
Springer front forks.. they are totally scratchbuilt using plasticard and a 2mm tube of brass.
Old 02-07-2012, 05:57 PM
cinqster's Avatar
cinqster cinqster is offline
Very nice work so far...especially on the clutch and primary belt - totally nuts!
For future reference for anyone else trying this, have a look out for old printer/scanners. I've got some rubber belts from them and they look great - not sure they have enough notches for 1/10th scale, but I've kept them for some 1/8th car projects and they are perfect for that.
Will try to get a photo!
Old 02-08-2012, 10:37 AM
daniel_k daniel_k is offline
niiice, as a Harleyfan I will follow that one for sure. I'm looking forward to your springer front end.
daniel
-germany-
Old 02-09-2012, 11:19 AM
Disca92's Avatar
Some progress on the forks..
Old 02-11-2012, 12:08 PM
Disca92's Avatar
I modified the springs and I scratched the kickstarter..
Chopper 300 joelwideqvist WIP - Motorbikes 155 01-29-2016 01:44 AM
i, chopper? american chopper i, robot theme bike tokes99 Sketching and Drawing 20 07-29-2004 03:03 PM
Samurai Jack! tonioseven COMPLETELY off-topic 9 03-02-2003 10:20 AM
Samurai Gold Paint?? CraigStables General Discussion 0 11-12-2002 07:10 PM
