1995 SSE no fire on #3 and #6 coill?
Car runs bad, pulled wires off coils and both cylinders are dead, replaced coil and module and same results. Need a place to start if anyone has any idea..Thanks
Re: 1995 SSE no fire on #3 and #6 coill?
OK, let me get this straight......you checked for spark on each cylinder, one at a time, and there was no spark on #3 cylinder #6 cylinder? Did you attach a spark tester to the end of each ignition wire to test each coil?
So you replaced the coil AND the ICM(were these new or used parts?)......and the same problem....once again, did you test this with a spark tester at the end of the ignition wires, one at a time? Have you checked the plugs on each cylinder? Have you checked the wires to each cylinder? Kind of Puzzling, since no spark on 3/6 is usually the coil or ICM..... |
| The Following User Says Thank You to Tech II For This Useful Post: | ||
21sprint (01-26-2012)
Couple things I would have done....swap 3/6 coil with 5/2 coil......if you now have spark on cyl#3 and cyl#6(but don't have it on 5&2 cylinders), then the coil is the problem......if you still don't have spark on 3&6 cylinders(put 5/2 coil back in original position and leave 3/6 coil off), attach a test light to the two connectors on the ICM for 3/6 coil....now crank engine....test light should flash when you crank the engine......if it doesn't flash, bad ICM....
