Old 07-13-2003, 04:23 PM
spoolinLSVTEC spoolinLSVTEC is offline
Send a message via AIM to spoolinLSVTEC
about to light my car on fire and push it down a hill
my crx still isnt working. it was throwing code 1, so i took out the o2 censor and checked it, but it was brand new when i swapped the zc in , about 4 mo ago. i've replaced the dizzy ignitor, the fuel pressure regulator, the fuel filter, the fuel pump, and checked all my grounds. i have checked over my vaccum lines but still dont know if they are correct. the car will idle fine and then when i give it gas quick, it stumbles or boggs down, but if i ease the gas to it, it will run up to 4000, where it stops and dies down again. my friend said it might be a clogged cat, but the motor ran just fine before i pulled it to put the tranny on. please if you have any ideas, let me know. has anyone else been in this situation?
Old 07-13-2003, 04:52 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
what engine?
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 07-13-2003, 05:55 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Originally posted by H4Bangin
what engine?
Originally posted by spoolinLSVTEC
...but it was brand new when i swapped the zc in , about 4 mo ago.
Old 07-13-2003, 05:59 PM
H4Bangin's Avatar
maybe u have some wires crossed or something
Old 07-13-2003, 06:03 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
You sure the ECU is workin' ok?
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 07-13-2003, 09:45 PM
91civicDXdude's Avatar
Im willing to bet you money it IS NOT a clogged cat. That rarely happens, and usually the symptoms would be a sluggish car, not one that wouldn't run quite right.
If you converted to MPFI, you might want to check your wiring on the TPS, as having this backwards will cause the car to run erratically. Make sure it is not throwing any more codes. and like the above person said, make sure your ECU is good.
Sometimes a code1 (o2 content) doesnt mean the sensor itself is bad, it could mean the sensor is reading out of its intended range, i.e. car is running very rich or very lean. check that out, especially if its throwing any other codes.
Old 07-13-2003, 11:37 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
give ya 10$ for it
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
