Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 01-17-2012, 10:32 PM
papason papason is offline
94 catalytic converter how do you know when it needs replaced? need replaced
My muffler is shot so was wondering when I replace it if I should replace the cat too??
What is the life span or how do you test them to know what kind of shape it is in??
About 155,000 miles on truck I assume both are original.
Old 02-12-2012, 01:38 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: 94 catalytic converter how do you know when it needs replaced? need replaced
There probably is some sort of flow test to check one, but likely not worth the effort.
I wouldn't replace it unless necessary, for one thing, they're $$.
If it is clogged, you'll notice it. One clue is if it starts struggling uphill where it didn't before.
If you have an O2 sensor before and after it, the system should see a problem a trigger a CEL.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
How do you know when to replace shocks?? anthonyn Rodeo | Passport | MU 3 10-22-2007 08:24 PM
how do you know if fuel pump needs to b changed? on a s-10 ('95) cros3599 S-10 4 07-16-2004 09:43 AM
how do you know when you re clutch is going? OoNismoO Engineering/ Technical 1 10-25-2003 11:14 PM
How do you know when an item is in stock at 1999.co.jp??? BOOSTD Car Modeling 6 09-09-2003 04:14 AM
how much hp does a catalytic converter give you? rendog24 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 04-17-2002 02:39 PM
