Old 10-23-2003, 09:41 PM
OoNismoO OoNismoO is offline
how do you know when you re gonna need a new clutch soon?
how do you know if you re gonna need a new clutch soon? anyone with any experience with it? does it get hard to shift? does your clutch burn a lot instead of clamping when its suppose to?
Old 10-25-2003, 11:14 PM
bustedratchet bustedratchet is offline
Re: how do you know when you re gonna need a new clutch soon?
Could be both problems you described. If its hard 2 shift you might have a pressure plate not releasing the clutch disc. About the slipping part, say if your in 2nd and you punch it does it slip ? if it does you need it.
How do you know if your clutch is bad? Drez7 Engineering/ Technical 6 05-16-2007 10:22 AM
How do you know when to change the transmission fluid? hosslake Elantra | Avante 3 01-25-2006 06:39 AM
How do you know when synchros go bad. Musashi3000GT 3000GT/Stealth 4 01-26-2005 02:47 PM
How would you know if your clutch was going out? chevy girl S-10 5 12-21-2004 12:51 PM
How do you know when an item is in stock at 1999.co.jp??? BOOSTD Car Modeling 6 09-09-2003 04:14 AM
