Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 01-14-2012, 02:10 PM
tkswan's Avatar
tkswan tkswan is offline
Air bubble?
02 LS V8 - 147k miles.
When the car is running down the highway, or moving with the rpms up, the heat is good. When I get to a stop sign or red light...the air turns cold. Thinking it was an air bubble in there somewhere, I had it pressure once and it didn't change. This time I had the thing professionally flushed. Still no change. The thermostat is good, it warms up normally. No other symptoms. All ideas welcome and greatly appreciated.
-tswan
Old 01-14-2012, 08:36 PM
joegr joegr is offline
Re: Air bubble?
It's your aux pump.
Old 01-15-2012, 05:34 PM
tkswan's Avatar
Re: Air bubble?
Thank you for the reply but can you tell me more about this aux pump?
whats its purpose?
where is it?
can i test it?
-tswan
Old 01-15-2012, 06:15 PM
Re: Air bubble?
whats its purpose?
where is it?
can i test it?
Purpose = enable the heater to work when the engine is at idle.
Where = Right side of the radiator, just above the DCCV (it's below the DCCV on gen II).
Test = With the car warmed up and the heat turned on, carefully grab the body of the aux pump and see if you can feel the pump motor running.
Old 01-22-2012, 08:10 AM
mvansant mvansant is offline
Re: Air bubble?
What is the exact name of the aux pump? I am trying to find the part and I am having problems locating the correct one. Any ideas where a cheap one can be found would be great help.
Mark
Old 01-22-2012, 10:29 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Air bubble?
Mark
Do you have the V6 or the V8? The auxiliary pump is only on the V8. On the V8 it is located in the coolant path between the thermostat housing and the DCCV.
-Rod
Old 01-22-2012, 10:32 AM
Re: Air bubble?
V8 2002.
Old 01-22-2012, 04:33 PM
danielsatur danielsatur is offline
Re: Air bubble?
Also do a coolant bleed procedure on the heater core with the heat on high, and with a little RPM's
The little black hose with plastic screw next to the aux coolant tank is used to work out any air from the heater core.
air bubbles on trans dipstick smantas Regal 1 05-14-2007 02:14 PM
Air bubbles in tranny fluid, 2005 4.2L V6 SwampRat013 F Series 2 07-09-2006 06:06 PM
Air bubbles? Sebstar Car Modeling 4 11-18-2003 12:20 AM
Tamiya Semi-Gloss Black X-18 / Air Bubbles djmr2 Car Modeling 12 07-01-2002 12:48 AM
Air Bubbles hAnGoOkNoM Car Modeling 7 04-15-2002 04:40 AM
