Old 04-13-2002, 11:49 PM
hAnGoOkNoM hAnGoOkNoM is offline
Send a message via AIM to hAnGoOkNoM
Air Bubbles
Im sanded my ITR body and after my 2 coats of primer and than 1 coat of blk spray paint air bubbles keep apearing! Any ideas wut to do? i sand the bubbles out and than when i spray again they reapear. What can i do?
Old 04-14-2002, 05:19 AM
primera man's Avatar
"P-Man"
Heat the can up in hot water first
Make sure the can is well shaken
It may be due to the paint going on to thick...I FIND BLACK IS A BAD COLOUR FOR AIR BUBBLES
If there is only the very odd bubble, pin prick it as soon as it appears can help to. Dont wait to long. If the paint is still very wet it will blend into the already wet paint.
View All My Models Here.
Old 04-14-2002, 06:16 AM
daggerlee's Avatar
How long did you wait between primer coats? Are you using enamel or lacquer primer? Enamel or lacquer body paint?
Seems like either 1.) Primer coat hasn't fully dried out yet, still releasing solvent gas which is causing bubbles or 2.) The body paint is too "hot" for the underlying primer coat and dissolving the primer beneath it, which is also very bad
Dan
Old 04-14-2002, 01:48 PM
IM using lacquer tamiya spray paint and i sprayed the 2 coats of primer and let them dry 24hrs each
Old 04-14-2002, 06:23 PM
S Brake's Avatar
S Brake S Brake is offline
Ferrari Guy
Make sure that your coats are very very light. just enough to barely cover the body.
The contents of this post may be fictitious.
Old 04-14-2002, 06:38 PM
parkcaka parkcaka is offline
after primers did you wash the body before black paint. i just had the sam experience with my black sti. if you wash primed car after sanding allow it to dry at least 3 hours. it looks really dry after about an hour but i think primer sucks some water inside so its not dry really. so when you spray bubbles appear.
i dont know, if you havent washed the body then i dont know the reason.
Old 04-14-2002, 09:17 PM
oh ya mb thats y i only dried it for 30min and than sprayed it
Old 04-15-2002, 04:40 AM
"P-Man"
Bingo
air bubbles on trans dipstick smantas Regal 1 05-14-2007 02:14 PM
Air bubbles in tranny fluid, 2005 4.2L V6 SwampRat013 F Series 2 07-09-2006 06:06 PM
Air bubbles? Sebstar Car Modeling 4 11-18-2003 12:20 AM
Tamiya Semi-Gloss Black X-18 / Air Bubbles djmr2 Car Modeling 12 07-01-2002 12:48 AM
