Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-06-2012, 02:51 PM
buckeyeguy's Avatar
buckeyeguy buckeyeguy is offline
2000 Mustang bogged down and died
OK I am starting over and going to simplify my question....what would make my #34 fuse (Instrument Cluster, CCRM, Data Link Connector, Securilock Transceiver Module) keep blowing. It did it first while driving (car felt like it was fighting against...or not very responsive) to acceleration. Then I was able to start it and it ran 5 min and then blew....now it is vlowing as soon as I get to accessory. I have checked the connectors but cannot find anything. HELP!
I have not modified anything. And its a 2000 3.8L Auto trans with 117K miles. Was running fine before this.
Jim
Old 01-06-2012, 07:06 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: 2000 Mustang bogged down and died
Can you get your head under the dash and have a look?
It sounds like something shorted out and went pop.
Old 01-06-2012, 07:31 PM
buckeyeguy's Avatar
I did try but didn't see anything that stood out. By the brightness of the flash I am surprised I could not.
Jim
Old 01-06-2012, 08:20 PM
buckeyeguy's Avatar
So I guess if something shorted out and it caused the symptoms it did. What is in that area that I might be able to narrow it down to?
Jim
Old 01-06-2012, 08:50 PM
Moppie's Avatar
Master Connector
Unfortunatly I don't know enough about Mustangs, but if there was a flash, then there will be some burn or scorch marks somewhere.
Is there a panel under the dash you can remove to get better access?
You need to find what made the flash and it may require some digging.
Don't be afraid to poke around with a test light as well.
Old 01-07-2012, 02:17 PM
buckeyeguy's Avatar
Well I have taken things apart and looked all over and cannot find any sign of anything being burnt from an arc. Having said that I guess I need to start looking into the cluster not working. Any tip or tricks on that?
Jim
Old 01-08-2012, 01:09 PM
buckeyeguy's Avatar
Update, I think with the fuse now popping the moment I turn the key to on, it must be a short (Duh) but my question is, can a CCRM do that or is more likely in the fuel pump?
Jim
Old 01-08-2012, 10:33 PM
Abella Abella is offline
although a fuel pump can do that i would think itd be your ccrm because the fuel pump is on a different circuit i think i have to check my owners manual but yeah unless both wires are stripped and the circuits are crossing it would have to be the something that is on fuse #34 i would also check the fuse base although i have never had it happen to my 2002 my bud had his 99 v6 and the base went bad and kept blowing fuse #25 also this may sound dumb but make sure its the right fuse it should be 20 amp
Old 01-08-2012, 10:36 PM
those were minor fuses also check major 4,5,6 for damage they are all 40 amp. 4 and 5 are ignition switch and 6 is cluster and pcm
Old 10-17-2015, 02:20 PM
axios axios is offline
I have a 94 3.8 had same issue had tests ran on alternator replaced fuel pump and had my hot wire to starter was barley on it, nothing wrong with alternator and fixed starter wire still same problem, then checked the alternator wires and right at the tip of the plug two wires were split and touching, separated and taped them and no more blown fuses
bravada bogs down and bucks when hot majman08 Problem Diagnosis 6 10-17-2015 02:23 PM
2000 ZX2 bogs down in warm weather ronman Escort 4 04-25-2006 12:36 AM
2000 gts bogging down jblu Celica 5 04-24-2006 08:01 PM
Van starts and then bogs down and dies after 5 to 10 seconds. benredmond Trans Sport 3 12-07-2004 06:13 PM
Engine bogs down and dies ivan8r C/K 1 09-05-2003 03:54 PM
