Old 03-14-2009, 10:28 AM
majman08 majman08 is offline
bravada bogs down and bucks when hot
i just left chicago to move to fl and as soon as i got to some of the big hills i had problems. oh was also towing my boat with 94 bravada when this happens. going up hill woulld start to bog down whebn i let off the gas it would buck . then if got off the gas enough it would still go but i had to feather it and my speed would keep dropping.. i would pull over at rest stops and wait till it cooled down and for awihle would have no problems ... the temp gauge was reading 200 the whole time so it wasnt overheating.... the closer i got to florida the worse it got as it was warmer and wouldnt cool down as fast and seemed to happen alll the time hill or no hill ... anyone with an idea please help.0
Old 03-14-2009, 11:28 AM
old_master's Avatar
Advisor/Moderator
Re: bravada bogs down and bucks when hot
Have you checked fuel pressure and leakdown?
You have to know how it works,
to figure out why it doesn't.
Old 03-15-2009, 12:55 PM
do not have access to fuel pressure gauge. should i buy one ?
could my problem be coming from my egr valve ?
can someone tell me why it says blazer problem diagnosis can i change that somehow thanks
Old 03-15-2009, 02:44 PM
old_master's Avatar
Advisor/Moderator
A fuel pressure tester is an invaluable tool for all CSFI and CMFI equipped vehicles, yes, get one. Check your private messages, you'll find a link for one.
Old 03-15-2009, 03:03 PM
Leeann94astro's Avatar
Leeann94astro Leeann94astro is offline
Because the Bravada is a Blazer with a different options pack. You'll get more exposure in the Blazer Problem Diagnosis section.
1993 Olds Bravada 4.3L CPI
1999 GMC Safari SLE AWD
2002 Chevy Astro LT AWD
Old 03-16-2009, 05:09 PM
trishharris trishharris is offline
Check spark plugs!
Old 10-17-2015, 02:23 PM
axios axios is offline
O2 wires grounded or sensors are bad or shot catalytic converter
Tags
bogging , bravada , bucking
