Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 01-05-2012, 07:59 PM
cshults's Avatar
cshults cshults is offline
How to change differential fluids and transfer case fluid
Hi guys -
Well after 4 years of a shudder free transfer case, the shudder is back. The last time I had this problem the encoder motor needed to be replaced, hopefully that's not the problem this time and that fluid changes will fix the problem.
This time around I want to change the fluids in the front and rear diff's as well as the transfer case. I'm sure it's not terribly difficult but I've never done this and am unsure about locations of the drain plugs and fill holes.
Can anyone help me out with this? I'd rather do this myself and not spend the money at the dealer or a jiffy lube type place.
Thanks in advance,
Chris
Chris S.
2001 Bravada Platinum Ed.
1992 Beretta GTZ
Old 01-05-2012, 10:02 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Re: How to change differential fluids and transfer case fluid
I saw this link below your post under "similar threads", I really like that new feature here. It's for a 2000 but should be the same for yours.
http://www.automotiveforums.com/vbul...d.php?t=213771
The Following User Says Thank You to ericn1300 For This Useful Post:
Chris Stewart (01-10-2012)
Old 01-07-2012, 07:29 PM
cshults's Avatar
Thanks, Eric. Changed fluids in both diffs and the transfer case today. The front diff and transfer case are extremely easy to change, the rear, not as much, I couldn't locate a drain plug so I ended up just taking it to jiffy lube for the rear diff.
The front diff was nearly bone dry, not good. Flushed it out with clean fluid and it took nearly 64 oz of new gear oil before it was at the proper fill level.
The transfer case fluid seemed fairly clean and did not look contaminated at all, but couldn't hurt to have new fluid in there since it was last changed about 40-50k miles ago.
Hopefully this will cure the shudder problem, need to drive it around some more and do the low speed tight turn test to see what happens.
Next will be to change the transmission fluid. Will have to investigate how to do that. I didn't spot the pan or drain plug for that when I was under the truck today..
Chris S.
1992 Beretta GTZ
Old 01-10-2012, 08:05 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
You drop the pan, replace the filter, reinstall the pan then fill with new fluid.
After I did the '92, once a year I'd draw out a quart through the dipstick tube then add new fluid to the full mark hot. After about 4 years, the fluid was bright red again.
It just turned over 192K a week ago....which is nearly half of the miles Eric's has.
Old 01-11-2012, 08:16 AM
ericn1300's Avatar
AF Premium User
Actually mine is down to 129k now. I had to change the digital speedometer. Kinda funny that I got one with almost exactly half the mileage of the old one 259K, still a daily driver and reliable enough for our Christmas trip, three passes over a mile high then a drop from 7,300 feet to sea level in under three hours, then reverse that on the way home. A drive a lot like my walk to school when I was young. In the snow and uphill, both ways
Front Axle and Transfer Case Fluid Capacity fire24resque Silverado 1 03-07-2006 02:27 AM
Transfer case fluid change David John S-10 2 04-19-2005 07:11 AM
Transfer case Fluid change IA-Suburban Suburban 5 12-15-2004 12:43 PM
Transfer Case Fluid Change? Senderofan TrailBlazer | Trailblazer EXT 1 07-23-2004 11:30 PM
Front Dif and Transfer case fluid change...is it difficult ? Alexxn 00 Si Blazer 2 04-18-2004 07:03 PM
