Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-01-2012, 10:48 AM
Crosst Crosst is offline
Aftermarket Fuel Pump Wiring
I bought and installed an aftermarket fuel pump. It has a different wiring harness than stock. I took a chance and wired it up and it works fine, but I got SES CEL almost immediately (P0442) which is EVAP purge valve solenoid. I also noticed that the car stinks now at the purge canister. So, I was wondering if a couple of the wires on the fuel pump power the EVAP and I crossed them up. If anyone has experience with wiring one of these aftermarket pumps up and maybe has a wiring map, that would be great!
Thanks
Todd
99 k1500 sub
Old 01-02-2012, 08:39 AM
j cAT j cAT is offline
Re: Aftermarket Fuel Pump Wiring
Thanks
Todd
99 k1500 sub
I know that they make two fuel pumps one with emissions and one with out. in AZ you will need the emission type.
with buying aftermarket fuel pump and your issues. post what the manufacturer is . where you bought it . perhaps a forum member can help.
I would have used a delphi fuel pump with emissions .
Old 01-02-2012, 08:42 AM
the OEM/proper fuel pump assy has a pressure/vacuum sensor. this is how the pcm determines the condition of the evap fuel vapor system.
Old 01-02-2012, 11:31 AM
I found this post on the Yukon forum
http://www.automotiveforums.com/vbul...d.php?t=138891
Since I have good functionality from the pump, I suspect I have reversed the sender wiring. Since the fuel tank is low, it is s good time to drop it today.
Thanks
Todd
99 k1500 sub
Old 01-02-2012, 01:38 PM
Thanks
Todd
99 k1500 sub
check out these pictures of a silverado 1999 vehicle. with this truck style the pump replacement is easier than with your suburban.
good pictures may help you ..2 connectors one for pump/sender the other is the evap system.
http://myoffroad.auto.officelive.com...mpRemoval.aspx
looks like this guy lives out your way..
Old 01-02-2012, 02:15 PM
Looks like the same pump I got. Unfortunately someone put gas in the Suburban and I will need to wait a bit to drop the tank. Fortunately they only put 1/2 a tank in.
Todd
99 k1500 sub
Warning: aftermarket fuel pump inlet screen 12Ounce Escort 1 06-19-2009 01:28 PM
2001 Astro aftermarket fuel pump whine! 2001 ASTRO DUDE M Bodies 7 01-26-2007 04:31 PM
Too little Voltage on Aftermarket Fuel Pump? Nayr747 Engine, Transmission and Drivetrain 4 11-21-2004 09:47 AM
Aftermarket fuel pump vjp64 Suburban 1 10-12-2004 08:15 AM
Fuel Pump Wiring Problem edrich1 Yukon 2 10-01-2003 11:42 AM
