Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 12-31-2011, 07:22 PM
taunop taunop is offline
oil leaking
Hi,
I have a 97 Sable, 3.0 DOHC ( I think).
There has been some engine oil leaking.
I took the car to the mechanic and he said there are two leaks.
1-Camshaft synchronizer is leaking and this repair needs immediate (or quick) attention. Part 137 labor 110.From parts the mechanic said that camshaft sensor will be removed as well.
2-Oil pan gasket needs a replacement parts 120 (gasket + new pan) and 370 in labor.
Since I am a student and budget is tight , I wanted to give it a shot and try the repair myself but after consulting the Chilton manual I couldn't find any information on how to replace the camshaft and it doesn't even mentions any seal I need to install. I have done much repair myself but with this one I am at a loss.
Could someone tell of how immediate this repair could be necessary?
Are those prices normal for such a job?
There are days when leak is evident and there are others where only a drop or so comes out, its not that oil leaks like from an open tap.
Thanks
Last edited by taunop; 01-01-2012 at 06:54 PM. Reason: fiex proper reason for oil leak.
oil leak?????? freakyfire05 Accord/TSX/Accord Hybrid 11 02-22-2009 12:44 AM
99 Burban Oil leak at Oil filter housing?? OZBIRN454 Suburban 1 07-31-2008 04:35 PM
95 LeSabre Oil leak on pass side above oil filter... AJsOffroad LeSabre 2 06-02-2008 06:48 AM
Oil leak and P/S leak rbsteve Escort 0 11-07-2005 02:44 PM
