Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series > N-Body Problem Diagnosis
Old 12-31-2011, 12:27 AM
Small1957 Small1957 is offline
Achievable
When the car is in park the park lights work, when I put it in drive an start moving the fuse for the park lights blows. What could be the problem:
Old 12-31-2011, 09:29 AM
Tech II Tech II is offline
Re: Achievable
A short circuit in a wiring harness that moves and grounds out as the car moves....what you can do, is replace the fuse, turn the park lights on, then start grabbing wire harnesses and moving them and see if the fuse blows, to narrow down your search area...it's obviously a rub through condition....
The Following User Says Thank You to Tech II For This Useful Post:
Small1957 (12-31-2011)
1992 Achieve SC- Heating issues GBC Chairman General Discussion 1 12-17-2003 09:54 AM
Is it possible to achieve 160HP or more HP?~~ kevin7 Street Racing 22 05-25-2003 07:06 PM
need help with achieving desired boost kungfujap Forced Induction 1 01-26-2003 11:13 AM
how to achieve this effect?? j.fuggi Tires and Wheels 8 03-06-2002 10:53 AM
