Old 12-30-2011, 01:09 PM
Vorkosigan Vorkosigan is offline
2000 GMC Jimmy - Suddenly not running right
I've got a 2000 GMC Jimmy that all of a sudden started not running right. Loss of power, idle is too slow, it's running really rough(can shake the whole vehicle), and won't stay running if I stop for too long.
The Service Engine Soon light came on and the error codes are as follows:
P0300 - Random/Multiple Cylinder Misfire Detected
P0147 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0155 - O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
I could use some help figuring out what's wrong. Otherwise who knows how long it will be before I can get a mechanic to even look at it. If it's something simple, however, I could probably fix it myself.
Old 12-30-2011, 04:21 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2000 GMC Jimmy - Suddenly not running right
With a missfire code
Check your secandary ign.
Start with plugs and check wires and cap.
Check for good hot spark to all plugs.
Make sure you have proper fuel pressure.
Clear codes and see what comes back.
Let us know how it goes.
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
Vorkosigan (01-03-2012)
Old 01-03-2012, 06:55 PM
Thanks for the help, but it was not a problem I could deal with on my own.
Luckily it seems I found a decent shop (I'll see if I still feel that way over time) and they were able to get it in right away. Looks like one of the fuel injectors failed.
Old 01-03-2012, 07:13 PM
MT-2500's Avatar
AF - Advisor
You are welcome.
Thanks for posting back how it went and what they found.
Good luck
MT
Car Trouble - GMC Jimmy '98 Snowbder09 Problem Diagnosis 4 07-21-2011 01:38 PM
1993 gmc jimmy key stuck wizard00 Jimmy 2 05-24-2011 05:09 PM
1996 GMC jimmy surging 600cuin Jimmy 1 10-05-2010 07:37 PM
Blowing ECMb fuse 1990 gmc jimmy 350 bmxer20n Problem Diagnosis 1 07-10-2009 06:47 PM
2000 GMC Jimmy 6 disk changer not working. cosmonaut Jimmy 2 02-17-2009 05:19 PM
