Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 05-22-2011, 09:18 PM
wizard00 wizard00 is offline
1993 gmc jimmy key stuck
I started my 1993 GMC 4x4, as i shifted out of park there was a clunk.
Then there was like a heavy roar as i drove, like i was in 1st gear. i pulled over and put it in park. i tried to shut engine off, but key would not turn off, i drove home, removed ground wire from battery and then popped coil wire off, key still locked in the on, can start truck but cant shut off. all shifting works fine. is there a relay,modole or something that may have blown? i did loose power windows for a few mins but they work fine now.
Old 05-24-2011, 03:50 PM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
Re: 1993 gmc jimmy key stuck
I would be happy to look into this for you. In order to do so, I will need the VIN for the vehicle. Please feel free to contact me via provate message. Thank you in advance and I look forward to hearing from you.
Tricia, GM Customer Service.
Old 05-24-2011, 04:09 PM
Scrapper Scrapper is offline
AF Premium User
did you try pushing up on shifter in park and try to turn key because it may not be going in park all the way?
1996 GMC jimmy surging 600cuin Jimmy 1 10-05-2010 06:37 PM
Blowing ECMb fuse 1990 gmc jimmy 350 bmxer20n Problem Diagnosis 1 07-10-2009 05:47 PM
1993 GMC Jimmy 4.3 4x4 switch problem kroms_001 Jimmy 6 01-22-2006 05:56 AM
1993 GMC Sonoma 4X4 - Stuck in first gear! brandi13 Sonoma | S-15 0 10-06-2005 01:09 PM
erg valve for 1993 GMC Jimmy mjohn Cars/Parts for Sale/Exchange 0 11-17-2003 11:45 AM
Tags
1993 , gmc , jimmy , key , stuck
