Old 07-09-2011, 09:00 AM
Snowbder09 Snowbder09 is offline
Car Trouble - GMC Jimmy '98
Hello,
I was on my way to work this morning and my car all of the sudden went from 55 to 35 and reduced drastically in speed. The service engine light came on. The car started jerking, but was still progressing forward. I pulled over and started the car back up. When I pressed down on the accelerator the car slowly jerk and met a speed of 35. It stayed at 35 for awhile then the car jerk and it started to speed up a little more.
I have never encountered this problem before and instead of spending my money to try and figure out what the problem is, I was wondering if you guys had any insight first.
Thanks!
Old 07-09-2011, 11:27 AM
jdl jdl is offline
Re: Car Trouble - GMC Jimmy '98
Any applicable trouble codes? Some of the national brand autostores used to check codes for free. If the mil lite is on, there should be codes?
How long since a tune-up? Use a gage and check fuel pressure.
Old 07-09-2011, 09:21 PM
4x4 blazerguy 4x4 blazerguy is offline
Smile Re: Car Trouble - GMC Jimmy '98
I know AutoZone still does code reading for free.
Old 07-09-2011, 09:55 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Thanks!
Welcome to AF!
Hopefully we can help
There are lots of things that can wrong with an engine, how much do you know about cars and fault finding?
Old 07-21-2011, 12:38 PM
jinxedjimmy jinxedjimmy is offline
It sounds like what happened when my oxygen sensor (or CA emissions sensor?) went. The code will tell you more about it.
Andy
1996 GMC jimmy surging 600cuin Jimmy 1 10-05-2010 06:37 PM
96 GMC Jimmy Help....O2 Sensor?? corhey88 Jimmy 1 02-15-2010 06:24 PM
96 GMC Jimmy black smoke, backfires, Timing? corhey88 Jimmy 38 01-31-2010 03:29 PM
Blowing ECMb fuse 1990 gmc jimmy 350 bmxer20n Problem Diagnosis 1 07-10-2009 05:47 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
Tags
1998 , gmc , jimmy
