Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 12-26-2011, 11:31 PM
dodgetruckborred dodgetruckborred is offline
W150 wont start.
Had problems starting for a year which was usually fixed by using ether and jumping it. It recently died while i was driving so i replaced the battery and alternator because they were on warranty anyway. Now i cant keep it running, it will start sometimes but when i hit the gas it backfires and dies. Anything will help. I've already changed the ecm, battery, alternator, rotor button, distributer cap, and coil. Have also tried timing the engine, but it seems that timing might still be the problem. Also i know that its getting fuel because i an see it in the carburater. I,ve also clamped the fuel line and took some spark plugs out and cranked the engine to try and unflood it. Thanks in advance.
Old 12-30-2011, 06:41 PM
jamesslcx jamesslcx is offline
Re: W150 wont start.
Dodgetruckborred, what year and mileage is your truck? If you haven't fixed it yet it may possibly be the timing chain, or I've heard of a clogged cat. converter causing similar problems. Does it back-fire out the carb or exhaust?
1991 wont start..motor from 1985 no spark HELP rwoodxtreme C/K 4 01-31-2010 10:19 AM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
97 yukon wont start yukon45427 Yukon 1 06-23-2009 07:24 AM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
03 Eclipse rs wont start mrcontreras Eclipse 2000+ 1 02-27-2009 05:49 PM
