Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 12-24-2011, 08:23 PM
scottman25 scottman25 is offline
98 mercury mystique shifting wrong only when cold out
Ok here is the runaround:
98 mystique v6. 133,575mi and 20k miles on rebuilt tranny 2 yrs ago.
only when it is cold out (in the 30's), it will shift hard between 1-2 and thwen the rpms will stick and stay around 2k until you stop and then the tranny will downshift to 1 and then everything is ok. then once the car warms up, and you shut it off and start it, everything is fine and the car shifts like a dream. I changed the fluid and not a lick of difference. any ideas, bad sensor maybe??? please help.
Scott
Transmission Delay & Hard Shift Into Reverse When Cold Only WillieEverlearn Caravan | Voyager 16 01-04-2009 09:58 PM
Vehicle stalls only when cold bad68chev C/K 9 02-26-2005 09:48 AM
Check engine light stops cranking only when cold Roger0021062 S-10 2 10-05-2004 04:40 AM
HELP !! Hard start with 89 Camry - Only when COLD !! fhs8860 Camry/Camry Hybrid/Vista 2 06-13-2004 02:46 PM
HELP !! Hard start with 89 Camry - Only when COLD !! fhs8860 Engineering/ Technical 4 12-18-2003 02:00 AM
