Old 12-15-2003, 01:42 AM
fhs8860 fhs8860 is offline
HELP !! Hard start with 89 Camry - Only when COLD !!
Hello everyone
: I have a 89 camry. It takes a lot of cranking to start the car when the engine is cold but starts on the first try when hot. any idea what could be the problem.
: Thanks
: Faisal
Old 12-16-2003, 07:46 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
Re: HELP !! Hard start with 89 Camry - Only when COLD !!
could be a compression issue.
when cold, the rings and seals contract and donot provide as much of a seal. this does not happen as much when it's hot out.
of course, this is ONE possible reason.
Old 12-17-2003, 09:24 AM
SaabJohan SaabJohan is offline
Can also have to do with the fuel, when the engine is cold it needs extra fuel since it won't vaporize as it does when the engine is hot, if it doesn't get as much extra fuel as it needs the mixture will be lean and a lean mixture is hard to ignite.
The oil is also thicker when the engine is cold, this means that it takes more power to crank it which can lower the speed of the cranking.
Old 12-17-2003, 09:28 AM
not much you can do about the fuel though.
you can switch to a lighter oil, but I wouldn't switch to anything not recommended by the manufacturer. Synthetic oils usually flow better.
Old 12-18-2003, 02:00 AM
Guys thanks for your replies. So it looks like i really cant do much about this problem. About the oil, i got a regular oil change from walmart.
Anyways Thanks.
hard to start when cold 88alldae Caprice 2 08-03-2009 09:16 PM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 08:52 PM
Will not start with key only when roll started whats wrong? soto 95 gsx Eclipse Problem Diagnosis 12 01-30-2008 08:28 AM
HELP !! Hard start with 89 Camry - Only when COLD !! fhs8860 Camry/Camry Hybrid/Vista 2 06-13-2004 02:46 PM
HELP !! Hard start and stalling with Camry - Only when hot !! gurup Camry/Camry Hybrid/Vista 4 12-15-2003 01:18 AM
