Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-15-2003, 01:25 AM
fhs8860 fhs8860 is offline
Post HELP !! Hard start with 89 Camry - Only when COLD !!
: Hello everyone
: I have a 89 camry. It takes a lot of cranking to start the car when the engine is cold but starts on the first try when hot. any idea what could be the problem.
: Thanks
: Faisal
Old 06-13-2004, 02:06 PM
zxie zxie is offline
Re: HELP !! Hard start with 89 Camry - Only when COLD !!
My 87 camry just had the opposite problem. It can be started when cold. After started it just run fine. But if turn it off, try to start the second time. the engine cranked but never start again.
Old 06-13-2004, 02:46 PM
gelcol gelcol is offline
Re: Re: HELP !! Hard start with 89 Camry - Only when COLD !!
try change the ignition coil I just add ignition coil to my old car just in case it wont start i switch it to the other coil. or clean the spark plugs and check the wires for lose connections 1st.
hard to start when cold 88alldae Caprice 2 08-03-2009 09:16 PM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 08:52 PM
Will not start with key only when roll started whats wrong? soto 95 gsx Eclipse Problem Diagnosis 12 01-30-2008 08:28 AM
HELP !! Hard start with 89 Camry - Only when COLD !! fhs8860 Engineering/ Technical 4 12-18-2003 02:00 AM
HELP !! Hard start and stalling with Camry - Only when hot !! gurup Camry/Camry Hybrid/Vista 4 12-15-2003 01:18 AM
