Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-22-2011, 02:49 PM
Da Burb Da Burb is offline
1996 Multiple Codes
150K miles. 2WD. Codes are 0141, 0151, 0154, 0161, 0300. It started with the 0151 and 0154 a few weeks back. I was waiting until the Christmas break to work on it. If I clear the two codes they would come back as soon as the truck got back on road again but it was only the two codes. I haven't cleared them for a while now and I have more. If I clear all these, only the 0154 and 0151 will return immediately, the others over a periods of a week or two. It leaks oil from a few places so I am going to be changing the intake manifold gaskets, oil pan gasket, timing chain cover gasket and tranny fluid/filter and I planned on changing the O2 sensor on the right before the cat because of the 0154 and 0151 but now with 0141 I am wondering if something else is going on to trip O2 codes on both sides. Not sure what to look for other than the O2 sensors. I changed pretty much everything in the fuel system and ignition system in May except the injectors. I was actually thinking I should replace them when I am doing the intake because the are right there. When should injectors be replaced as routine maintenance? Any ideas on what to look at for the other codes? I wouldn't think these are all separate problems. Thanks for the help.
Old 12-22-2011, 04:54 PM
j cAT j cAT is offline
Re: 1996 Multiple Codes
those O2 codes tell me the O2 sensor heater fuse is blown. should be 20 amp.
p0300 could be anything on a 1996...converters , distributor bearing ,low fuel pressures.
154 code maybe sensor or wires. if fuse is blown check all wires for damage. repairing sensor wires can be tricky and cause the O2 sensor not to work correctly.
Old 12-22-2011, 05:10 PM
777stickman 777stickman is offline
I didn't see what motor you have. Below is all for a '98 5.7
The only fuse in the system for all o2's is the ENG 1 fuse. #21 20a in the under hood fuse box.
Bank 1=Drivers side exhaust. Bank 2=Pass side.
Sensor 1=Pre Cat. Sensor 2=Post Cat.
P0141= Bank 1 Sens 1 Heater Performance. Most likely o2 sens, wiring or VCM.
P0151= Bank 2 Sens 1 Low Voltage. Indicating a lean condition on bank 2. Check fuel press, exhaust leaks up stream of the sensor, vacuum leaks and PCV system.
P0154=Bank 2 Sens 1 Insufficient Activity. Check for exhaust leaks upstream of the sensor.
P0161=Bank 2 Sens 2 Heater Performance. Same as P0141 just different sensor.
P0300=Random misfires. Fuel press, injection system and/or ign system.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 12-22-2011, 10:56 PM
It's a 5.7
The fuse is good. Tomorrow I will start checking things before I take it apart.
Old 12-23-2011, 09:11 AM
It's a 5.7
if the wires look repaired/spliced etc on the O2 sensor this is usually where this issue is created.
make sure the feed goes to the O2 SENSOR FOR HEATER.
Old 12-24-2011, 08:24 AM
autojoe autojoe is offline
fuse 1 20 amp underhood fuse box for both heaters.....if no connection problems then maybe a vacuum leak or faulty 02 sensors.could check voltage and grounds at sensors and also bias voltage from pcm on signal wire....that would tell you if wiring was okay especially the signal wire.
Old 12-24-2011, 01:25 PM
I used my poor man's Oxygen Sensor diagnostics tools and swapped both O2 sensors on the right with the left and the codes followed the O2 sensor after the cat so I will be replacing that. It looks original meaning it isn't a Bosch. Same manufacturer stamp that is on the Cat...AC.
Is changing the fuel injectors (about $230-250) worth the money on 96 with about 150K miles? This part last longer or are they prone to failure soon?
1996 eclipse gst MT - no spark to cyl #2 and #3 alarche Eclipse Problem Diagnosis 2 07-07-2009 06:14 AM
Grand Voyager Multiples Codes, Help! Jare Caravan | Voyager 1 11-19-2006 02:49 AM
89 suburban has multiple codes, help requested. 9396 ULTRA Suburban 3 11-05-2006 02:31 PM
Multiple Codes - Cannot determine problem balewisca Problem Diagnosis 1 10-19-2006 12:12 AM
Multiple codes nathanmontez C/K 2 04-06-2004 07:42 AM
